Question about Tablets & eReaders
'Data usage warning' is on my tablet. What does it mean and how do i correct??
No service after factory resetting tablet
This is normal. A factory reset sets the item back to the day it was installed by the manufacturer, no software you have installed or data. There is usually a warning before you proceed to tell you to make backups and ensure you have license numbers etc for the software.
Sep 23, 2017 | Tablets & eReaders
Don't understand gigabite usage. What does .129 mean and how many gigabites do I have left?
I'm not exactly sure what your question is, but.. .
1 gigabyte is 1000 megabytes.
.129 gigabytes is 129 megabytes.
Feb 23, 2016 | Samsung 32GB Galaxy Note Pro 12.2" Tablet...
How can i fix my Asus tablet it keeps shutting off?
Warning:- Hard reset will Cost your data, remove the microSD card
Hard Reset the Tablet
1- Switch Off your Tablet
2- Press and hold Power and Volume down key (in some case it can be Volume up)
3- Android logo with exclamation mark will appear, select recovery mode
4- Select Wipe Data
5- Select Yes- delete all user data
Now Tablet will be free from pattern lock
Different Hard reset factory wipe methods for Android Tablet
Feb 16, 2015 | ASUS Tablets & eReaders
Can you transfer your apps from your tablet to a SD card? The tablet is a Tel9Q. If yes how do I do it please.
In your settings you can find 'applicaton manager' find the app in question and press it. There should be a 'move to sd card' button. That should transfere most of the app data to the card for less tablet memory usage.
Feb 09, 2015 | Tablets & eReaders
My daughter irulu tablet won't turn. On. Help
Try a factory reset!
Press and hold vol + and power for 10 sec. android appears with warning triangle. press vol - and power menu will pop up select wipe data/factory reset. once it says data wipe complete select reboot.
Jan 03, 2015 | Tablets & eReaders
Find usage for iPad
settings, general, usage,
Oct 15, 2014 | Tablets & eReaders
What does it mean when the charging light is flashing when charging
Blinking white simply means the tablet is communicating with the internet, checking mail, updating news, weather, etc.
Try to run the tablet down to the 2% warning, then plug it in and charge till it is full.
Jul 12, 2014 | Hipstreet Flare 2 9 inch Tablet with 8GB...
Hi, I charge my samsung tablet, may or may not use it. the battery icon does not show correctly. some times it says that "charge the battery" but i leave it aside and after for example one hour i check the...
You are likely running an old version of the firmware / ROM. See if Samsung has a new version, or if you are comfortable with rooting visit XDA Developers forums to learn how to get a newer version with more up to date power management and battery conditioning updates.
Dec 04, 2013 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
