Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
HD Spins, and makes a "ticking" noise.
It sounds like the drive is spinning, but I'm not able to see it connecting to the computer. I've pluged it into different outlets and different usb ports, even on different compters. I'm not sure if tearing appart the my book and installing it in the computer will solve anything...
  • 69 Answers
Seems the drive is faulty the have a two year warranty you can check this on:
http://support.wdc.com/
try it on a diffrent machine. whatever you do don't open it if it is in warranty
Posted on Jul 25, 2009
    New Friend:
  • 47 Answers
If it's clicking the drive is gone. If you have important data on it, put it in a ziploc bag and into the freezer for a few hours, then take it out and quickly connect it to the computer. This trick usually works long enough to be able to get your data off, but for all other intents and purposes the drive is dead.
It does happen that the controller in the drive dies, and it may work if you take it out of the enclosure and put it into the computer directly, but if it's clicking it's most likely mechanical failure of the drive.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like you droped it 1 too many times drive is probaby fubar buy a new driveand start again
try to return drive for warenty though
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
I can't get the computer to find the hard drive. Turn on hard drive in makes a ticking noise sounds like something is spinning. Then it stops and nothig ever happens. HD Extreme HD2-U2 How can I...
This hard drive is faulty. The ticking sound is the read/write head banging back and forth - known as the click of death.
There are companies that can recover data from hard disks BUT it will cost you an arm and a leg for their services.
May 11, 2011 | Alpha Digital 1 Bay HD2-U2 (hd2u2) USB 2.0...
I was copying a file from my WD My Passort Essential 750gb drive to my computer last night when suddenly i heard what sounded like a scraping sound, i unplugged the HD and tried hooking it back up but NONE...
Noise from the hard Disk not a very good Sign.
Try the device on a friends or a relatives PC. if you have the same result , you might be having a defective HDD. best would be to take it to a local repair shop for recovery of DATA. ( if you have warranty now would be a good time to use it)
May 08, 2010 | Western Digital WD Passport 250GB Portable...
My HD makes loud ticking sounds while on, pc doesnt read it.
Your HD has probably gone bad beyond repair. you should contact some data recovery shop if there was crucial data in the HD
Feb 07, 2010 | Verbatim VER95327 USB Hard Drive
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Western Digital Elements HD doing a clicking noise and no access
It might be the power adapter. I had one of these and two Maxtor external drives that just clicked that way and it turned out their adapters were bad. You can check with another adapter if you can borrow one from another drive, or use a replacement from Radio Shack. Make sure you get the same voltage and current rating marked on the original.
If the adapter isn't at fault, the small circuit board in the enclosure may be the trouble. You can remove the drive from the case and connect it to directly to a computer power supply to see if spins up properly.
If the drive still doesn't spin, it's bad. This is a common way for a drive to fail. Unfortunately, this leaves you with a drive that you can't read. Hopefully you've backed your important data up on CD or DVD.
May 21, 2009 | Western Digital Elements powered by WD 320...
Computer doesn't recognize my Lacie HD
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Dec 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a barracuda 7200.7 80 Gbytes. The dirve spins but stopped booting. Started making clicking noises. I smacked it a bit a few times. Now, the system doesn't recognize the drive in BIOS at all. I...
this hard drive is toast and sadly you are half the reason as you never, ever ever open or hit a hard drive.  There are data recovery firms however, they are very expensive.
Nov 27, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
389 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
