Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do u enlarge on scan mode - Canon PIXMA MP160 All-In-One InkJet Printer
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-27
Posted on Sep 04, 2009
  • 742 Answers
Basically, you cannot enlarge the scan mode. it captures the object right as it is placed in the scanning area. However, some scanning software bundled with scanner hardwares comes with the zoom utility. It is operated as follows:
Open your scanner software first and let it initialize.
1. Preview Scan first.
2. From the Preview area, you can press "+" or "-" to zoom.
3. Select the zoomed portion where you want to scan.
4. You're done!
Regards!
Posted on Jul 25, 2009
  • 69 Answers
Under the pixma software there should be a slider by the scan/pre-scan which can be adjusted or it may have an advanced setting menu.. keep me posted on this
How do i enlarge a scanned photo
Your printer software should have an enlargement feature. If not, print he photo then copy it using enlargement feature.
Feb 13, 2015 | HP PhotoSmart Office Equipment & Supplies
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
How can I scan a document, enlarge the print and send it as an attachment to an email?
Generally, when you scan a document, it is a photo of the item. You can use a photo editor to enlarge then save the enlargement, once done, file, send to, email recipient, this should attach the scan as an attachment
Oct 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Sep 14, 2009 | HP Photosmart C6280 Printer
Enlarging copies
To enlarge when using the copy function on the machine, you simply do  the following:
  • Press the Copy button to activate copy mode
  • Choose "Enlarge/Reduce"
  • Press the left or right arrow key until you reach "Custom (25-400%)"
  • Press OK
  • Type in the % you want it enlarged, press OK.
  • Start copying away with Color/Mono Start.
Jun 03, 2009 | Brother MFC 490cw Color Inkjet...
Scans are enlarged after switching to vista 64bit
hmmm... just the set pixels properties to medium..maybe the pixels properties is to high..it can cause long time scanning and large images results ..thank you
May 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Scanning
well..that means you wish to enlarge it , right? you'll need to use the scanner, save the image, then enlarge it with Photoshop or something along those lines..
http://tinyurl.com/6qcpgy
Aug 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
219 people viewed this question
old marine
old marine
