Question about Whirlpool Washing Machines
What would be wrong with a whirlpool cabrio washer if it doesn't complete the washing cycle? Does it have a timer?
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
keithd2704
  • 56 Answers
SOURCE: whirlpool washer ultimate care II lsq8500JQ1 top...Problem
Ok folks to change the lid switch on these and many top loading Whirlpool, Maytag, Kenmore, etc is quite easy.
Steps to replace the lid switch:
1. Remove unit from AC.
2. Remove the loading door from the unit, or using some duct tape tape it closed.
3. Using a small flat bladed screwdriver find the 2 release catches on the front of the unit between the top cover and front panel. These are just snap claps to hold the top cover down. To release the top you will need to compress the latch using the screwdriver. Start with one side, then the other. Once you have released both clips the lid will lift up just like the hood of your car.
4. You will now be able to remove the lid switch from the unit.
5. Install the new switch and close the hood of the unit.
6. Test the repair by running the unit though a complete cycle.
A great place to order the replacement part for the unit is:
www.appliancepartspros.com
They ship same day on orders placed before 3pm EST. Overnight shipping is available, however I usually opt for the 2-3 day ground shipping and save the money.
If this switch replacement does not take care of the problem, you might need to replace the control board located under the front panel. This replacement is also very easy and takes about 10 min from start to finish.
Hope this helps everyone. Cheers,
Keith
Posted on Oct 21, 2008
SOURCE: washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Posted on Mar 17, 2009
jsrock516
  • 5911 Answers
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Posted on Jun 11, 2009
richroth
  • 9472 Answers
SOURCE: my whirlpool cabrio washing machine keeps giving
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Posted on Jan 05, 2011
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
I have a Cabrio washer model #WTW7340XWO. I have had 4 shirts ruined with bleached out spots all over them after washing in this machine. We use NO bleach in the detergent. What is wrong?
Hi
It seems that it needs cleaning... you can run your washer with nothing inside it at its hottest temperature setting with 2 cup of vinegar inside the unit. After this clean the drain pump assembly completely, also clean the drain hose and drain pump filter, the spots should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
May 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain or spin
the timer may need to be replaced.. it might not be clicking on the spin cycle. try moving the dial manually to the spin mode.
Jul 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
