Question about Toshiba Televison & Video
I have a Toshiba TV Model #46XV545U that turns off 5-6 seconds after turning it on. Could it be the main board or the power supply? Or something else? Thank you for your help.
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
  • 195 Answers
SOURCE: olevia 437-s11
Most likely the CCFL inverter has been the problem all along....
Posted on Oct 10, 2009
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Posted on Nov 13, 2009
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
SOURCE: 42rv530u toshiba tv no sound no picture change
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Posted on Apr 25, 2013
I have a Vizio E50-C1 Model #LTCWSKAR Power supply # (X)ADTVE2420AD4 Main Board #GXFCB02K009050X
You need to find out which board the led driver resides on. The main board sends a signal to the power supply board to turn on the LED's Look on the power supply board for swollen capacitors. They all have to have flat tops. If any are bulged, they have to be replaced www.shopjimmy.com. TV Parts Universal TV Stands DLP Chips ShopJimmy These guys can tell you which board you need.
Jul 28, 2017 | Vizio Televison & Video
What is causing my LCD tv to turn off on my Toshiba 52hl167 tv.
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 13, 2016 | Toshiba Televison & Video
Toshiba 50l3400u 13 blon jumper to get rid of blinking
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 25, 2016 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
Toshiba LCD 2009 TV picture won't show when turned on but sound works fine. Picture shows after 4-5 minutes. Help...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Toshiba Televison & Video
What parts to fix a blank screen besides power supply and main boards (have tried both)?
STOP Get a SERVICE MANUAL and follow instructions before you make it any worse by "Mucking around with it" it needs to be serviced in a set careful methodical way u cant just replace boards and hope as those boards may damage or be damaged, to have any chance u need to get the book plain and simple less expensive too.
Aug 21, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
My Sanyo PDP-42H2W TV WON'T TURN ON AT ALL, HAS BEEN MOVED, DID I JAR SOMETHING
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jul 18, 2012 | Sanyo Televison & Video
Display problem on 46" Toshiba flat TV
From your detailed description, it sounds that the the back light lamp/s has the fault. Just visti this site for more details. The site name is 'Eelctro-help'. Type this site name in google search box and search. It is an electronic equipments service help site, subtitled so, can be located either at the bottom part of the first search page, or at the top of the second. you can search for it by yahoo too. Can get detailed description about this fault and how to repair it.
Jun 16, 2012 | Toshiba Regza Cinema 46xv545u 46 Series...
Plug in tv hear some clicks but nothing else
If more than one click----main power relay is turning on and then off.
Indicates a problem in main power supply---either the supply or something connected to it is pulling it down.
Suggests problem is on Secondary side of power supply.
Mar 13, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
We have a Toshiba 52 inch TV, model # TP50G50, manafactor date on it is July 1997. The picture & the sound went out all at once, do you know if it's a fuse or something more serious? It's hard to haul...
It is a power supply fault. The power supply is a switched mode power supply and supplies 5 volts for the difital logic and high voltages for the high voltage parts of the tv relating to the screen display components. When the high voltage part of the circuit breaks or goes short circuit then the power supply shuts that part down leaving the low voltage rail of 5 volts..hence the standby still working. So... you need to be looking at the power supply board where the mains goes in but be aware of the mains voltages in this area if you arent experienced in electrics. The board will still hold 240v if the power supply has an open circuit load
Aug 02, 2009 | Toshiba Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
