Question about Vizio Audio Players & Recorders
VIZIO TV SPEAKER BUZZING ON SURROUND SOUND. I turned off the surround sound audio and turned everything to the left speaker and the buzz is gone. Is the speaker on the other side out?
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: buzzing in speakers of cinema surround
I have the same problem, tried routing my speaker wires away from power wires and that doesn't seem to work
Posted on Jan 03, 2008
SOURCE: No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Posted on Oct 01, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
I just bought logitech 5.1 surround sound speakers, but its making a buzzing noise how do i fix that please. could it be that my sound card is not good enough?
if you buy a 5.1 speaker you also need 5.1 sound card that supports the speakers. although it will still work with ordinary sound card but you can't actually use the feature of the speakers. the buzzing sound can cause by loose connections of the audio cable or audio connector. you can also hear a buzzing sound if you connect it at the wrong port. just remember the color codes
green - audio out (for speakers) red - microphone blue - line in or audio in black - digital audio
Apr 22, 2011 | Logitech X-530 5.1 Speakers
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Surround sound does not work
If there are any power cords from other components near speaker wires the electric interference transmits through speaker wire causing a buzz.
Aug 20, 2009 | Denon AVR688
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Audio
Go into the audio menu of the tv and turn the internal speakers to on. There will be an obvious selection for this but if you can't find it write me back. Hope this helps.
Mar 25, 2008 | Panasonic PT-52LCX65 44" HDTV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Buzzing in speakers of cinema surround
i have the same problem. haven't tried the fix yet, but someone recommend connecting the two pronged power cord to an adapter that switches it to a 3 pronged (adds the ground prong). i guess the adapters are less than a dollar and can be bought at most places.
Dec 04, 2007 | Audio Players & Recorders
Top Vizio Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
