Question about Cell Phones
Iphone 6 is stuck on itunes support/ resore & can't shut down phone si i can't restore
ViewFinder
  • 33 Answers
SOURCE: Iphone "There is not enough memory available"
There needs to be sufficient disk memory on the PC to hold the contents of the iPhone (8GB or 4GB) plus some extra. This is because the iTunes backs-up the iPhone before the restore. Check and clear some space on your PC hard drive and try again.
Posted on Sep 07, 2007
silentspoon
  • 62 Answers
SOURCE: Iphone problem "please connect to Itunes"
restore to the latest firmware (1.1.3) and try again
Posted on Feb 17, 2008
  • 116 Answers
SOURCE: windows xp shuts down when i connect iphone to try dwnload itunes
your pc has a virus
Posted on Jan 09, 2009
SOURCE: Iphone, not reading sim, not connecting of itunes...
another way to restore it would be to turn the device off, then hold down the power button and plug it into your cpu still holding the home button and it should show up in itunes
Posted on May 05, 2009
z89s
  • 225 Answers
SOURCE: iPhone stuck on Startup logo
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Resetting the iPhone should not remove or delete any data or settings.
Posted on Aug 08, 2009
My iPhone 5 was frozen. I forced a shut down and now cannot sign back in. When I touch the numbers, the phone does not read it.
Try to restart the iPhone: Press and hold both power button and home button together until iPhone turns off and starts again (Apple logo appear on white screen). Release both buttons when you see the Apple logo. Let the phone boot up. It should be ok. If not,
You can update/restore your iPhone using iTunes installed on a Mac or Windows computer.
Steps to follow:
1. Please turn off the phone.
2. Press and hold the home button and connect the USB charging cable to your phone and to Mac/PC running iTunes.
3. When iTunes connect logo appear on iPhone screen, release the home button.
4. iTunes will detect your phone and prompt you to update/restore your phone.
5. Click on update.
6. Let iTunes download and install iOS update on your phone. It will prompt you once finished.
If the update is failed, iTunes will prompt you to restore (this process will erase all data from your iPhone), select restore and wait to finish.
After restore process is done, you may restore your iPhone backup (if you have backed up your iPhone before).
Sep 11, 2017 | Cell Phones
How do you factory hard reset a apple iphone with the model number A1332 an no sim?
iTunes enables you to restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone with iTunes as follows.
1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
How to Restore iPhone 6 Plus to Factory Settings
Aug 28, 2014 | Apple iPhone Cell Phones
My iphone just turned of and it had full battery now it wont turn back on any help ?
Hi
Try holding down your power button and the power button for about 10secs or until an apple appears, your phone should then load up. If not then please follow the steps below to restore your iphone..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option. If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Jan 01, 2011 | Apple iPhone Smartphone
My apple iphone16gb i lost the passcode and now this is only for emargency calls only i tunes couldn't be connected plz help me to unlock it
Hi, you will need to restore you phone but because itunes isnt seeing your phone you'll need to turn it off and hold down the home button for around 10secs and connect to itunes and release then itunes will bring up a message saying the phone has been found in recovery mode, from there continue with restore (follow from step 6 below)
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 10SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
    After a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
Jan 01, 2011 | Apple iPhone 3G
Iphone wont turn on
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
Dec 26, 2010 | Apple iPhone Smartphone
My iphone is not recognized and cannot be activated for service
You need to restore the iphone as a new iphone
Dec 26, 2010 | Apple iPhone 3G
I locked myself out of my iphone, wrong passcode, cant get in :(
you need to restore the iphone as a new iphone...this does mean you will loose everything on the phone though.. so before you follow the steps below connect your phone to itunes on comp and transfer purchases from iphone to comp ( on windows select file on a mac also select file)
Dec 25, 2010 | Apple iPhone 3G
Iphone will not get pass apple logo even after i reset it several times
hi you need to restore your iphone as new...hope this helps!
Dec 25, 2010 | Apple iPhone Smartphone
My IPhone 3Gs shut off and is not getting back on ....... I tried cold reboot aswell but do-sent workk ..... plzzz helppppppppp
Dec 24, 2010 | Apple iPhone 3G
My i phone cannot be restored
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Sep 06, 2009 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
