Question about Maax Home
Where can I find suction cover for Maax Pearl CS 636? Purchased in 2006, discontinued. Tried Maax and Google replacement parts to no avail
5 Suggested Answers
  • 2176 Answers
SOURCE: Bostitch N80 End cap. Part N/A no help from company. Need part N70167
I think that you might have other problems, but you might try calling FRY FASTENING at 513-851-2233 for assistance. I used to work there and they should be able to help, if not let me know
Posted on Jan 12, 2012
  • 6468 Answers
SOURCE: cs 440 evl air filter
echo was bought out by sthil check with sthil dealer
Posted on Sep 04, 2012
  • 717 Answers
SOURCE: I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to:
Posted on Mar 12, 2013
SOURCE: replace suction hose on Hoover steamvac agility cleaner Model F6215-900 The replacement hose is no longer available online or from Hoover. The water in carpet is not suctioned up due to broken hose.
Alternatively, you can repair the hose using silicon self-fusing repair tape which can be found at Walmart (I found it next to the duck tape in the painting area) which is good for water-tight seals and remains flexible. This will benefit you later should your new part break again.
Posted on Sep 07, 2016
I need the blade retainer part # 636-100
Google search your manufacturer make and model and the words replacement parts. If vendors are available, you can find it in the search results.
Mar 19, 2015 | Kitchen Appliances - Others
Can't turn on Whirlpool
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 09, 2014 | Maax Home
Pearl Trillium diverter and hand held shower
The faucets on your Pearl tub do not come from Pearl. They were supplied by the local plumber who installed the tub.
Go to your local plumbing store and match up what you have.
US Parts Center
Jan 04, 2014 | Maax Pearl By TRILLIUMbla Pearl Trillium...
Delonghi EAM3500 problem in power board (part no 5232109900)
There are lots of Delonghi spare parts on the website komtra
Unfortunately the page is in German.
A new Power board is available for 72 euro
Dec 03, 2013 | Coffee Makers & Espresso Machines
Tub goeson then turns off
This sounds like a bad motor. It sounds as if it is overheating.
You will need the model number and brand of pump in order to find the correct replacement.
us parts center
Apr 04, 2013 | Maax Pearl By CS42wh Pearl CS42 in White
The pump surges where's the impeller
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
Feb 16, 2011 | Maax Pearl By CS60wh Pearl CS60 in White
Pump stopped working I have sensatouch controls. One day the unit wouldnt turn on when i touched the sensors. Power to the pump is on. also to the heater. Both have power. not sure how to test pump. GFCI...
you may have a bad switch how good are you with electrical you could go get a regular toggle switch that has the amp load of your pump and wire it to the pump and see if your pump comes on if it does well then you know your sensatouch controls are bad if you think you can handle it and you have a multi meter i will walk you through it
Jun 29, 2009 | Maax Pearl By CSP5wh Pearl CS-P5 in White
Broken back massage jet unable to purchase locally
Hi robrezza,
Here's the number the Pearl/maax Plant.
For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
Please rate this response and Good Luck, Phil
Jan 18, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Please help
The battery door assembly is available as part number:
636 049 8389 compl cover,battery cost: $24.61
May 20, 2008 | Sanyo VPC-G200 Digital Camera
Home Logo
Top Maax Home Experts
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
