Question about PRINTER Office Equipment & Supplies
My laptop says printer is offline. How do I get it back online?
  • 20 Answers
SOURCE: canon mp160
First step I would try is; unplug printer usb cable, then power down printer, reconnect usb cable to printer, power printer back on. If all this fails then lets try one other possible fix. Go to start select RUN & type services.msc, ok now you should have a services window that popped up. On the right hand side locate "Printer Spool" and right click on it, then select "Restart". this should refresh your printer spool. Hope this was helpful.
Posted on Sep 05, 2007
PABLOCSA
  • 1124 Answers
SOURCE: turning my printer from offline to online
Check your printer connections.
Go to printer folder and clean all pending jobs.
Turn off your printer
Turn off your computer
Turn on your computer
Turn on yor printer
Check the status fo the printer must be "ready" (at the printer folder)
If not replace the printer cable.
Is still the problem remain, uninstall an reinstall the printer.
Posted on Oct 08, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Posted on Mar 02, 2009
SOURCE: When I try to print my printer is showing as offline how do I get it back online
Phoned Canon today with the same problem. All I had to do was right click on the MP620 printer in printer control panel, then make sure that "Use Printer Offline"is not selected. Worked for me. Goodluck
Posted on Jun 18, 2009
How do i get my printer back on line?
NOT SURE IF THIS LINK WILL HELP YOU OUT....
Click the "Start" button and then click "Devices and Printers." Right-click the printerand select "See What's Printing" to display the print spooler window. Click "Printer" and select "Use Printer Offline" to remove the check mark. The printer should come online at this time.
How to Bring an Offline Printer Online ' Chron.com
smallbusiness.chron.com/bring-offline-printer-online-54836.html How do get my printer back on line Google Search
Dec 12, 2016 | PRINTER Office Equipment & Supplies
How do I get my "offline" HP 5524 printer back online?
Check or reinstall your printer's driver in your PC or Laptop. You can search it by pressing in Google "HP 5524 Driver Download" ...
#NZ
Jul 28, 2014 | HP Office Equipment & Supplies
Offline to online for printer
restart both Printer and laptop. you need the printer to be showing as online, reinstall printer driver if it does not work.
Apr 01, 2014 | Microsoft Windows Live Mail
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
There's a small chance this might be your fix.
Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    My printer is offline - how do you get online
    delete printer drivers
    if ur using from an usb then
    restart ur pc or laptop
    and reinstall drivers
    check if any error message is showing on ur printer
    Nov 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Printer offline
    Go to control panel and printers and faxes on your laptop and when you see the printer icon for the printer, right click on it and left click on use printer ONLINE. make sure then that the laptop is communicating with the printer.
    Apr 13, 2008 | Brother HL-2070N Laser Printer
    24 people viewed this question
    Top PRINTER Office Equipment & Supplies Experts
    Gene
    Hardeepak Bhambh
    Hardeepak Bhambh
    Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
