I need help in reconnecting D-link 624 for wireless ability and also to connect SMC Skype phone on one wireless function..forgot password and now the D-link is on default because I reset it..Please hep..it's been three day now, I have read but just don't get
you need to connect your computer to the router, if you can connect wireless start by wired connections.
if you can access internet then , you are connected to the router.
if there are other computer wired to that router have your wireless LAN card unblock from the router, it might have been block or the wireless capability of the router is disabled
try to access the router configuration either by wired from your computer or the other computer that is the only way to verify why you cant connect to the router wirelessly.
the important thing is the IP address of your computer and the machine number which you will get when you have entered the configuration utility.
Okay. You have reset the router. If you don't know the website to go to, then go start, run, cmd.
Type tracert telus.net
The first ip address to come up is the router.
When you are connected wired, then go to the website and proceed with the wizard. Enable encryption if you want, and give it a name. If you are going wireless, then disconnect the desktop/laptop. Let windows find the wireless connection and enter the encryption name and key.
The same thing applies to the iphone. Once the information is entered, then you can use the iphone.
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not...
(More)
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not work. Once the router was hooked up, couldn't get online. The tech is saying the router is faulty, but it worked just fine with Comcast. Switching from Comcast because cost keeps going up and going up again next year. Is D-Link compatible with DSL?
m belkin will not let me play animal crossing (wii) online, but i can play and do anthing else that...
(More)
m belkin will not let me play animal crossing (wii) online, but i can play and do anthing else that is online with the wii without any problems.
