What is matter? - Computers & Internet
How do the values for total mass before and after reaction demonstrate the law of conservation of matter?
  1. The law of conservation of mass, or principle of mass conservation, states that for any system closed to all transfers of matter and energy (both of which have mass), the mass of the system must remain constant over time, as system mass cannot change quantity if it is not added or removed."
In other words matter cannot be created or destroyed, only converted, into heat, energy, work, or other matter.
If your system is not closed (it probably isn't) and mass does not remain equal, then it is most likely that energy was gained or lost by the system. This most likely was in the form of heat.
You will need a pretty good scales to detect this though, as a tiny amount of matter = a huge amount of energy
Jan 22, 2015 | Computers & Internet
2 wired t-stat
doesn't matter. simple on and off single pole single throw switch.
Mar 29, 2014 | True GDM-45 Refrigerator
If torque converter not set to the mark in transmision will it not start car 96 honda accord lx automatic do it matter one guy say it don't matter
Shouldn't matter if tight. That's company specs so its well sealed. And by tightening too much gonna break things.
Aug 10, 2013 | DoALL Vairable Transmision Band Saw
Does the decor of cat furniture matter?
That is really a personal choice. You can create your own if you have a specific style you are wanting to achieve. Most of the material you should be able to get at Home Depot or other home improvement store.
Personally, for just a couple small pieces I do not think it matters. Some people on the other hand will want it all matching with their home.
What really matters is, are your cats using it? If they are not, then it does not matter how good it looks. :-)
Jul 23, 2012 | Cats
Charger wire came out can i fix it & does it matter which wire goes to which side
yes it matters what side they go on one side is ac power and the other is dc power the ac is for the headlights
Jun 01, 2012 | Craftsman Garden
Does it matter if use upper or lower case in your email address?
Hi there! :) it doesnt matter if your using UPPER or lower case on yahoo email however when it comes to password that matters :)
Oct 04, 2011 | Yahoo Mail
What is matter?
Matter is a substance that has inertia and occupies physical space. According to modern physics, matter consists of various types of particles, each with mass and size.
The most familiar examples of material particles are the electron, the proton and the neutron. Combinations of these particles form atoms. There are more than 100 different kinds of atoms, each kind constituting a unique chemical element. A combination of atoms forms a molecule. Atoms and/or molecules can join together to form a compound.
Matter can exist in several states, also called phases. The three most common states are known as solid, liquid and gas. A single element or compound of matter might exist in more than one of the three states, depending on the temperature and pressure. Less familiar states of matter include plasma, foam and Bose-Einstein condensate. These states occur under special conditions.
Different kinds of matter can combine to form substances that may not resemble any of the original ingredients. For example, hydrogen (a gaseous element) and oxygen (another gaseous element) combine to form water (a liquid compound at room temperature). The process of such combination is called a chemical reaction. A chemical reaction involves interactions between the electrons of the atoms, but does not affect the nuclei of the atoms.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Apple QuickTime VR Authoring Studio 1.0
What is chemistry?
Chemistry - is the science of matter and the changes it undergoes. The science of matter is also addressed by physics, but while physics takes a more general and fundamental approach, chemistry is more specialized, being concerned with the composition, behavior (or reaction), structure, and properties of matter, as well as the changes it undergoes during chemical reactions.
- It is a physical science which studies various substances, atoms, molecules, crystals and other aggregates of matter whether in isolation or combination, and which incorporates the concepts of energy and entropy in relation to the spontaneity of chemical processes.
Jun 07, 2011 | Computers & Internet
I have a universal remote i dont know if that matters
Matter for what? Most universals work on most brands no matter what kind of set it is. Look the code up in the user manual and plug that code in for yur set and it should work.
Dec 05, 2010 | Televison & Video
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
