The video is coming out in black and white - Televison & Video
What is the wires colors coming out of the jvc
Memory (+12v Constant) Yellow
Ignition (+12v Switched) Red
Ground (-) Black
Power Antenna Blue
Amplifier Power-on signal Blue/White
S p e a k e r s
Right Front (+) Gray
Right Front (-) Gray/Black
Left Front (+) White
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
hope that helps.
Feb 21, 2017 | JVC Car Audio & Video
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
All game are coming in black and white
are you using the red/yellow/white cable? make sure they're plugged in correctly.
Apr 13, 2014 | Nintendo Wii Console
PDG-DSU30 black and white video
check your HDMI/VGA cable this is sometimes cause the color lost. change it or try another cable...
Dec 05, 2013 | Sanyo PDGDSU30 Video Projector
Need to know how to connect to tv it comes on but in black and white
If you're using composite video cables (red/white/yellow) but your TV doesn't have a yellow jack to plug into, plug the yellow cable into the green "Y" plug instead. If there is more than one set of video jacks on your TV, make sure you're using the first set, usually labeled "Video 1" or "Component 1". If it still comes up in black and white after all that, you may need to look in your TV's settings menu to see if there's an option to change the settings for that port from Component to Composite.
If you're using component video cables (red/white & red/blue/green) make sure the cables are all plugged in to the proper color-coded ports on the TV. Mixing up the video cables can cause the image to show up in black and white
May 12, 2012 | Video Game Consoles & Games
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
Games are only coming through in black and white
when you switch it on hold down the power button for 4 seconds and it runs the display set up
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
My dvd player keeps coming up in black and white
sounds like the video processors on the input are bad
Apr 28, 2007 | Hyundai ImageQuest HQP501HR 50 in....
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
