Question about Sewing Machines
Why is my bottom stitching nesting? I can not get it to sew without none of the bottom stitching sewing
  • Sewing Machines Master
  • 8,899 Answers
Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension at the midway point (this is a basic beginning point but may need to tweak this for your particular machine).
Posted on Apr 28, 2017
  • Sewing Machines Expert
  • 458 Answers
Sounds like the tension is wrong somewhere. Or machine incorrectly threaded.
Posted on Apr 27, 2017
My sewing machine makes loose threads under the cloth
It is your top thread tension causing the thread on the bottom of the cloth to be loose. Make sure your machine is threaded properly and the thread is seated correctly between tension discs.
Make small adjustments and do a test on scrap fabric until the stitches are tight.
Jul 12, 2017 | Sewing Machines
When i first start sewing the thread will bunch up and make a rats nest how do i stop thisa
That is called thread nesting or bird nesting--or what I like to call thread "barfs."
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk so the thread will seat completely.
Bring the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while taking the first stitch or two. It may be beneficial to manually turn the handwheel for the first couple of stitches. It also helps to have the take-up lever at it's highest point BEFORE starting to stitch.
Birds nest under the fabric big loops of thread top side looks good...
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
How and Why to Bring up the Bobbin Thread
Apr 01, 2017 | Sewing Machines
Adjusting the stitches on White sewing machine 425
Adjusting stitches how? Are the stitches too short, too long, is the tension off, are there loops of thread accumulating (bird nests), thread pulls out of the fabric, is the top thread not picking up the bobbin thread????
Mar 10, 2017 | White Sewing Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
Dec 22, 2016 | Singer Sewing Machines
I'm getting a 'bird's nest' of thread on the bottom of my stitching...Why
needle thread tension is too light
increase that tension setting
Nov 19, 2016 | Sewing Machines
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
When i start to sew it binds up from the bottom
be sure to hold the top and bottom threads in back and away from machine as you start to sew. once you have sewn several stitches you can let go and continue sewing. sometimes this is all that is needed to avoid the "birds nest" on the bottom of the project.
Feb 23, 2013 | Euro-Pro 7500XH Mechanical Sewing Machine
Rats nest on back of fabric
make sure the machine is threaded according to the operations manual & the tension adjustment is according to the operations manual says
make sure the needle is not bent, and also the correct needle for the machine & fabric
if none of these work it needs to be taken in to be check
Jul 18, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Apr 23, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
