How to fix buletooth speaker on a ibasket.it connects and was playing but just stopped when I hooked it to a chargeer
Radio speakers no sounds
This is either an easy fix or can't b fixed there is a cord with twO ends on end hooks up to the radio one hooks up to the speaker if the one end isn't hooked up to the radio it should still play but if the cord is connected to tue radian and not the speaker it will "play" but there will b absolutely no sound this might be ur problem and all u need to do is connect the cord to the speaker If possible but if not u might need new speakers
Jul 20, 2014 | 2011 Harley Davidson FLHTCUTG Tri Glide...
I have a 1989 oldmosbil cutlass ciera and i upgraded to a new pioneer radio and it keeps saying amp error after a few moments of playing . What do i do
This is referring to the internal amp. Make sure none of the speaker wires are touching each other or metal. if the only speakers hooked up are the 6x9's then one or both of them probably has a bad voicecoil and is shorting out causing the radio to protect itself. Replace the 6x9's and you should be okay.
Jan 14, 2014 | Clarion DXZ438R CD Player
Synergy 10 sub light is on, but no sound
Pop the speaker out and make sure the spade terminals are still hooked up.
Mar 18, 2013 | Klipsch Audio Players & Recorders
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
May 23, 2012 | Acer Aspire One Netbook
Whats wrong when my lenovo ideapad speakers start distorting every now and then when sounds are playing? How do i fix this problem or get it to stop?
Try turning down the volume, small speakers in general can't handle a lot, if you still have trouble, the speakers may need to be replaced or the audio output chip. Hook external speakers to see if that will cure it, if no change! replace the ic chip.
Apr 08, 2012 | Computers & Internet
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
I have a fisher ca-9335 integrated stereo amplifier thats hooked up to sanyo tp 1010 turn table and plays out of yamaha ns-70t speakers. a simple jvc cd player is also hooked up to the speakers but not to...
Something doesn't add up. You mention two connections to the speakers - CA-9335 and a "simple jvc cd player". Is that true? If so, you might want to UNconnect the CD from the speakers and run it into the receiver where it belongs. An amp isn't designed to share the load with another live device; or even have electrical contact with anything BUT speakers.
Did you actually find documentation that supports this hook-up? Or just winging it?
Feb 20, 2011 | Audio Players & Recorders
My sub woofer has recently stopped working. I borrowed and hooked up a friend's subwoofer and still doesn't work. However all my other speakers in the car are still working. Could this be the amp? If the...
If you only have the sub connected to the amp, the other speakers would still play, if they are just connected to the head unit. I would check for power and remote power to the amp, and check the ground, if those are ok, I'd say the amp is bad.
May 21, 2010 | Rockford Fosgate Punch 401S Car Audio...
Everything works the speakers are hooked up i just
connect one speaker at a time .If one speaker or speaker wire is bad it will cause all audio to mute.connect one speaker at a time
Jul 30, 2009 | Pioneer DEH-P3500 CD Player
Labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Feb 07, 2009 | Labtec Spin 70 Computer Speakers
 Grubhead
Grubhead
