Question about GE Refrigerators
Hi. My ge profile artica , psc23ngna ww lights up inside, but no digital displays, hense nothing else works. I thought to look for the defrost timer, ut, nowhere to be found.
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Posted on Jul 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Posted on Jul 27, 2009
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
GE Profile Artica no display
I would inspect the wires that are located at the bottom left freezer hinge, opening and closing tends to break the wires over time. crimp the broken wires into a sleeve type connector, there will be little to no slack to use wire nuts. If the wires are perfect, you might need a new display board, but the wires are the prime suspect...
May 02, 2016 | GE Profile PSI23SGR Arctica¿...
Ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
    I have a GE Profile ARtica side by side. Ice maker is acting up
    The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
    Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
    My GE profile artica refrigerator freezer is not freezing properly. possible solutions
    Bad thermostat maybe. Does it freeze up at the back ? Could also be a bad defrost timer.
    Jun 30, 2009 | GE Refrigerators
    GE Profile Artica side by side stainless steel wont get cold
    The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
    Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
    Coils ice up
    appears to be the defrost timer,unit should have advanced out of defrost within the time you listed
    Jul 17, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
    GE Profile JGB97 Self Cleaning Oven Controls won't work
    You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
    I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
    I hope it works for you too. Please let me know at the following:
    Good Luck,
    Charlie Popeck,P.E.
    Consulting Engineer
    Feb 06, 2008 | Ovens
    Refrigerators Logo
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
