Question about Nordic Track Exercise & Fitness
There is no tension on my nordic track a c t - Nordic Track Exercise & Fitness
SOURCE: operating manual for cx1050 nordic track ellpitical
I just downloaded a copy. It's 32 pages.
Posted on Feb 19, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
  • 832 Answers
SOURCE: Nordic Track elliptical E7: The tension belt came
If you are looking at right hand side of unit you have the flywheel next to it adjusting tension plate.If you have your manual handy it will show how to loosen this part so you may loop over the small idler pulley which goes around the much larger pulley wheel if not here is the web page to go to and its on page 21 Hope this nugget will help!
Posted on Apr 10, 2010
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
I have a Nordic Track C2255. When I turn it on the motor run, but the belt won't move. I'm thinking that replacing the MOTOR CONTROL BOARD would solve the issue, but need to know before I spend the $.
You must observe 3 things:
Open the cover from motor
1) See if the Drive belt or belt for motor is Loose?
if does, adjust the 2 bolts for tension belt motor the deflection will be 1/8"
2) or Too tight loose the 2 bolts , and loose little until you have deflection for 1/8" and tight the bolts again, keeping the deflection for 1/8"
3) See if the belt is Cut!! replace it, by new one.
Nov 01, 2017 | Nordic Track Exercise & Fitness
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
Nordic track a.c.t. classic elliptical belt tensioner
You have to loosen the underside bolt as well as the 10mm bolt on the side . The 10mm bolt locks the adjuster in place. The underside 16 mm bolt is the adjuster.
Dec 07, 2013 | Nordic Track NordicTrack Treadmill, A2550
Nordic track console seems frozen
Since I don't know the model # I will take a wild guess and say they maybe batteries in the upper console that need to be replace or if it has a power supply in maybe the upper console that has failed. Get back to me if I'm off the mark thanks!!
Jun 29, 2010 | Nordic Track Exercise & Fitness
Missing a part on the tension belt for a Nordic Track Achiever
Go to click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
May 29, 2010 | Exercise & Fitness
Manual for a Nordic Track Personal Performance
May 13, 2010 | Nordic Track NordicTrack Professional...
The track stops when you put weight on it.
It sounds as though you do not have enough tension on the running belt or the belt that drives the front roller from the motor is slipping. You need to identify which is the culprit and then adjust to get more tension.
Apr 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
37 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
