Question about Garden
How to clean a carberator on aTH 48 brushcutter
Carberator linkage
You can find information about the B & S engines in their web site.
Jul 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Stihl brushcutter [four stroke] wont rev.
Check the valve clearances, remove the rocker cover to expose the tappets. Adjustment tools can be bought online or from your local dealer.
Jun 18, 2012 | Stihl String Trimmer Brushcutter Service...
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
Gas/oil ratio for a Jonsered LR 300 brushcutter
Clean fuel and a good quaility two stroke oil mixed at 50.1
Apr 19, 2012 | Garden
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Homelite brushcutter wants to staret but stalls
ckeck for cracks in the fuel line sometimes they will crack and **** air, also the carb could need to be cleaned
Feb 21, 2010 | Homelite Mighty Lite Lawn Trimmer
Do I need Special grease for Brushcutter/Trimmer shaft
No grease is grease but there is sillicone used nowadays as it just looks clean to use. Now check if it does use some kind of oil in the system.
Aug 03, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
