Question about Garden
Problem wiyh TH 48 brush cutter when pressing speed the engine chokes and off
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Chain saw starts hard, have to start it with the choke on all the time wheather the engine is warm or cold. the engine will not idle with out it stalling.i replaced the spark plug,thefuel line,fuel filter...
Sounds like dirt in the carb. Pull carb apart and spray out real well with gum cutter or carb and choke spray. Be sure to remove the needle valve and rinse all holes and ports. Use COPPER wire, like a strand from automotive or speaker wire to run through each hole. rinse everything a few times
Feb 20, 2011 | Husqvarna Garden
What are the other two screws for above the idle screw?
The one closest to the engine is the idle mixture screw. Out is more gas=richer
The other is for high speed mixture. Again out ccw (counter clock wise) is richer
1/8 turn makes a huge difference. Temp of engine critical. Make sure it is up to operating temp before turning anything. If it won't run turn them out 1/4 turn at a
time and see if it will run without choke or even 1/2 choke.
Feb 06, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
I have a SC30 model weed whacker and need "bulb as...
I've found the most inexpensive location for this as eBay. Typical costs are about $7.00 delivered. This is a very standard bulb assembly for the Ryobi: PART#1885121
It would generally be available at your local lawnmower or small engine repair shop as well.
May 21, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Poor running
sounds like the card needs to be cleaned thoroughly.
May 04, 2010 | Homelite Mighty Lite Lawn Trimmer
I have not used my bike since 1 month,its engine is turning off wen the speed is reduced,what shall i do?
Usually it will happen with all the petrol vehicles which was unused for some days or it is kept at very coll temperatures. Use the choke lever and start your bike. Keep it in same state for 5 minutes. once your engine heats up, then restore the choke back. If still the problem exists, then adjust the screw type adjustable know to increase the throttle level to keep th engine alive in slow speed.
Aug 03, 2009 | 2006 Hero Honda Glamour
Same thing for me.
http://www.petessmallengine.com/
Jun 29, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Grass trimmer cuts out unless choke is open
IF IT HAS A HIGH SPEED SCREW TURN IT COUNTER CLOCKWISE TO RICHEN THE HIGH SPEED CIRCUT. ONLY NEEDS TO BE TURNED A LITTLE AT A TIME TILL IT SOUNDS RIGHT.
Mar 14, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
