Question about Garden
18 Volt cordless trimmer battery powered indicates fully charged. Will not start. Model P-2002-12
    Sergeant:
  • 163 Answers
If you leave constantly charged it goes stale. this could be the culprit. are the contacts clear of all corrosion
Posted on Apr 27, 2017
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Aug 08, 2016 | Ryobi 40-Volt Lithium-Ion Cordless String...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
18 volt trimmer is new, first time I charged battery over 10 hours it only ran for about 15 mins. charged again until green light, over 3hours used about 3 times , start with full charge, only lasts...
This could be the life of the battery as there is another question along much the same lines. I suggest that you take it back to the dealer and discuss it with him and take it from there. Take into account that any attempt to fix or adjust any part of the machine will void your warranty.
Jun 13, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
The instruction books indicates that a green LED light will come on when charging and go off when charge is complete. Our NHT518 hedge trimmer only shows a red light, and after charging all night the red...
Check the contacts on the charger and battery are clean. They can be cleaned with IPA or meths.
Make sure the battery charger is slid fully onto the battery, it may take a little bit of pressure to do this because of the springiness of the contacts.
May 02, 2011 | Black & Decker NHT518-1 18-Volt Cordless...
Bought trimmer last year...battery no good this year...will not charge
Check that your charges is working - charge light on the unit or test output voltage. If these are ok, you will have to buy a new power pack for your trimmer or get a battery specialist to make up one for you. This will be by far the cheaper option.
May 01, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Feb 21, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Batteries run down fast
if you are lucky you will get about 40 mins out of it but it will loose it charge when stored
Jul 26, 2010 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
