Question about Maytag Washing Machines
I have a maytag mle2000azw stackable washer and dryer.
When i push the start button the washer cycle starts and then quits after a few minutes and the on light goes off. the more i push the on button the shorter the time on is.if i leave it for a while then it goes again eventually i get through the full cycle.
SOURCE: washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Posted on Dec 26, 2007
gwshaw71
  • 83 Answers
SOURCE: Dryer not Starting Consistently
You have a motor that is gone bad.
Posted on May 09, 2009
  • 278 Answers
SOURCE: My dryer (frigidaire stackable washer/dryer) just
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Posted on Dec 09, 2009
caroldon
  • 17130 Answers
SOURCE: My Maytag stackable MLE2000AYW washer
Youmay be right as the timerr can cut off due to poor contacts or faulty timer action. The best you can use a good switch cleaner to wash off dirt( with the main power OFF) , use a brush to clean , a good air jet to blown out dirt and wash the contacts with the cleaner as youa re switching ON/OFF the switches.
Once the contacts seems clean allow time to dry off and recconnect washer to mains. If there is a marked change repeat the work if not the prime suspect can be the timer unit.( make sure your door lid swiches are good, clean them also)
Posted on Nov 05, 2010
KevinWhite
  • 1902 Answers
SOURCE: Hi, Have a Maytag LSE1000 stackable w/d. Has
Hello
Washer not draining completely is caused due to clogs/blockages in the drain hose. You can start by checking the drain hose and clean the drain pump filter of any foreign particles. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
