Question about Sewing Machines
Viking/Husqvarna 5710 sewing machine is stuck in reverse. Reverse button isn't stuck, but doesn't pop out by itself anymore. Stitch dial isn't in between stitches. Put wd40 in the insides, didn't help
  • Sewing Machines Master
  • 11,493 Answers
Uh-oh. Don't use WD-40 on your machine... WD-40 becomes sticky with time and will seize the mechanics...
Wondering if there is a spring under the R button that perhaps is broken or collapsed.
Posted on Apr 27, 2017
Stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website and selecting "dealers" link.
Feb 11, 2010 | Husqvarna Viking 1
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at
Jan 25, 2010 | Husqvarna Sewing Machines
My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Oct 07, 2009 | Husqvarna Viking 1
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
Jun 03, 2008 | Husqvarna Viking 1
Viking Husqvarna 1610 sewing machine won't go in reverse
Check with an authorized Husqvarna Viking dealer. Check Husqvarna Viking website for dealer closest too you.
Feb 26, 2008 | Husqvarna Viking 1
Husqvarna 5710
Try ebay or contact an authorized Husqvarna Viking dealer for a user manual. They should be able to order you a replacement manual. Check Husqvarna Viking website for dealer closest too you.
Dec 06, 2007 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
