Question about Kenmore Dryers
My Kenmore Ellie H4 dryer had an electrical smell and was very hot. I paused the dryer but it kept running.
SOURCE: Kenmore dryer doesn't get hot but drum rotates fine
I read on another page
1) One of the thermostats could have a reset switch on it to cure problem... do not know where to find it or what it looks like! ....
2) May need to replace the element...
3) Could be the exhaust thermostat / or heater and thermostat complete/ check continuity...should be normally closed(complete circuit)
Any help to you ????
Best wishes willow
Posted on Mar 14, 2008
huuum
  • 750 Answers
SOURCE: Kenmore Dryer-Smell of gas at start up
did you call public service to check for a gas leak?
Posted on Feb 03, 2009
  • 19 Answers
SOURCE: kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Posted on Feb 21, 2009
  • 57 Answers
SOURCE: Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
  • 99 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
The dryer is working but it smells like it is getting hot. any ideas?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 22, 2011 | Kenmore Elite HE4 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
Jan 21, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
