Error mesage 1
Wont print
The machine's been printing fine. Then it stopped printing and gave error message #a1-4111
Remedy
1) Turn the machine off then on. If the error persists, turn the machine off again.
2) Remove the right cover.
3) Check if the connection between main board and motor in the main drive unit are correct.
4) If the connection is OK, replace the motor.
5) If the problem persists, replace the main drive unit.
It like a service call.
Apr 03, 2016 | Samsung CLX-6260FW
The error mesage "printer off
go to printer folder
click right mouse button on printer icon and select "use this printer online"
If your printer still wont print check communication cable.
At last, try to reinstall printer driver.
Apr 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Need to know what the ! light means
In normal working condition Green light will glow means printer is in on line.
If any light blinks then the printer is waiting / under process any printing job
If Red light glow then it shows some ERROR mesage.
(paper jam, cartridge error etc.)
Apr 15, 2011 | Office Equipment & Supplies
I get a mesage saing unsuported catrigeand it cant be because it is a new one!!!what do i do?
Which printer is that? also you get this error even if you have inserted the new pair of cartridges when the Printer's print head is damaged....try cleaning the print head inside the printer.....
Jul 03, 2010 | Computers & Internet
Mesage send error
i think the problem is with your mobile setting or mobile phone
Jan 18, 2010 | Cell Phones
Error mesage wont go off ...previously had low ink so changed catridges but no ink error wont go away
1. have yopu removed the cover lable.
2. Try re-seating the cartridge.
3. If still the same, Try another cartrige even if it is the old one and see if the error changes. If it does then you have a bad cartridge.
4. If this does not work try uninstalling the printer driver and then re-installing driver.
Jul 10, 2009 | HP DeskJet F380 All-In-One Printer
I KEEP GETTING A UO71 ERROR MESAGE WILL NOT PRINT
Thats a defective ink cartridge error, whichever one is turned off when you open the cover is the one you need to replace.
Apr 08, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Ds game
i guest the regin code reason that why you may not able to play around, becasue the ds system not match the games card region code.
Nov 03, 2008 | Video Game Consoles & Games
22 people viewed this question
k24674
jasbo
jasbo
