Using Challenge charger for dead battery, but have forgotten how to interpret lights. Initially, all lights on, but after five hours, these are still showing. Don`t think its charging.
SOURCE: Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Posted on Sep 08, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
In short, it works like a charm.
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: ryobi battery charger
The same thing happend to my charger, i let it cool down and now the green light goes off and shows red again. thanx for that post
Posted on Mar 22, 2009
  • 154 Answers
SOURCE: Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Posted on Jun 11, 2009
  • 699 Answers
SOURCE: My sony cybershot charger is
Most probably the battery
Please dont forget to vote if you liked my answer
Posted on Feb 11, 2011
How do I use a battery charger to charge my dead battery on a 2001 camaro
The red clamp on the charger goes to the + sign on the battery. The black goes to the -. I you want a deep charge(best) set the charger on 2 amps and run it for 8 to 12 hours. If you need to get the car started, set the charger on 225 amps for just a couple of minutes. Start the car while it is on..2 amps can charge forever. 20 amps for 30 minutes. 30 to 40 amps for 15 minutes. 225 amps for five minutes..DO NOT charge 20+ amps for hours. It will kill the battery
May 12, 2014 | Cars & Trucks
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Light goes on my kone but it won't work
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Nov 15, 2009 | Dewalt 18 Volt Compact Drill Kit
1995 Nissan 240sx will not keep running.
you need to replace your battery.since the alternator is supposed t o charge the battery. y dont you start your vehicle, have it run for 1 hour or go on an hours drive, come back home, turn it off,after five minutes start the vehicle..see if it starts.if it does not, that means your battery is dead.
hope this helps
kind reagards
Mar 10, 2009 | 1995 Nissan 240SX
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
I have an Olympus c770 - the battery charger is not working. The light is not red or green and the battery has been the charger more than 24 hours yet when I put in the camera, the battery is still dead....
Either the charger is dead, or the battery is dead, or both are dead. You should take the charger to a dealer who has the batteries in stock and get everything checked. You may end up having to buy one or both.
The charger is using electronic sensing with a microcontroler. It is very difficult to simply check with a standard DVM. With the earlier generation of chargers we were able to do a simple check on these chargers.
Jerry G.
Apr 20, 2008 | Cameras
Blinking red light
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
hope this helps. thanks.
Nov 13, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
