Question about Garmin GPSMAP 76 GPS Receiver
Map76 will not set to current date and will not display current tide info
    Brigadier General:
  • 8,619 Answers
Hi
Please go into Setup Menu and then restore the GPSMAP76 setup menu to the factory settings by pressing MENU and then with Restore Defaults highlighted press ENTER. If still you face same issue then you need to install MAP updates.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 25, 2009
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
Jan 03, 2015 | Health & Beauty
Timex W-225 -- the tide and temp button are non-responsive
have you try changing the battery...?
or-
did your watch has been been dropped?
Sep 09, 2008 | Timex Watches
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
I have a Northstar 6000i that will not display the tide track information. It has for 3 years,and now has a message stating that it can't display the information for the current date.
Probably the data didn't go past 2010. I have a Northstar 951XD, and first time out this year, no more tide track data - my manual says it only went fron 1994 - 2010. So how to get updates?
May 15, 2011 | Northstar 6000I GPS Receiver
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
Wrong time
To set the time do the following:
Setting the date and time
Press the Back/Options button ((the left pointing green arrow)).
You may need to do this more than once until the main menu appears.
Select Extras Date & Time. The current date and time are displayed.
Press and hold the Back/Options button.
Select Set Time or Set Date to change the time or date settings.
Select Date Separator, Date Format and Time Format to adjust how the date and time are displayed.
Select the options you want.
Mar 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Manual Information/Owner Guide
Also,
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
Garmin GPSMAP 76 GPS Receiver Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
