Question about Bobcat Welding Tools
How do I remove fuel tank on 225g bobcat welder
5 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
RixsFixes
  • 2200 Answers
SOURCE: looking for an instruction manual for my miller 225g plus
You can get this manual from the following link http://personafile.com/Miller-Welding-Equipment-BOBCAT-225G-P9207349821373.htm
Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
  • 3 Answers
SOURCE: bobcat welder will not kick down between arcs, its
Simple first, make sure you have it set to auto idle
Posted on Mar 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How do I remove and
Which engine on your unit do you have?
Kohler
Robin
Onan
Subaru
Diesel
There are 11 different 225 models there shoule be 2 letters in front of your model number I need those letters.
The 907209 is a 23 Hp Kohler engine unit and the 907210 is a 22 Hp Robin(Onan) unit.
Parts list
http://www.millerwelds.com/om/t4434l_pt_mil.pdf
Looking at the slot in the side of the fuel tank it appears that the bottom pan has to be separated from the unit. That would involve unmounting anything with wires attached from the base and supporting them. Engine frame, transformer / reactor, side panels, end panels battery and lower brace. I don't see any other way. I would try working from the engine end.
In all seriousness
I would contact Millerweld here: http://www.millerwelds.com/service/contactus.html
Mention your on a very remote worksite, have the replacement part in hand and would like to know if there was a service manaul or any techical assistance available for the tank change.
Even with my 40 years of experience this would be a task I would have to study up close and personal to sort out exactly what the sequence would be to change the tank. It appears to be a very major evolution that could go very wrong very quickly resulting in some major damage if you are not careful.
Kelly
Posted on Sep 16, 2011
Miller Bobcat 225G was sitting for about a year I put new gas new fuel filter new sparkplugs and cleaned out the carb it cranks good but wont start I have no spark to the spark plugs
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 08, 2017 | Bobcat Garden
I have a miller 1995 bobcat 225G with a onan motor with a external fuel pump and out the back of the fuel pump is a whole that oil is coming out of what would be causing this to happen?
it could be a stop solenoid hole or a simple oil filler hole that the plug has fallen out of
contact an onan service center and ask the service person what would be missing
Jun 18, 2016 | Miller Welding Tools
Miller gasoline tank leaking from meter
Depending on machine model and sn you need to order the fuel gauge repair kit from a distributor. It will have all of the parts needed and instructions on the removal and installation of the new part. This is a commom problem that we are seeing with the Bobcat and Trailblazers. I can drop ship the part from Miller to you if needed. Feel free to contact me at (803) 609-8518 William Scott.
Jun 12, 2012 | Bobcat Miller 225 Welder Generator 907209...
Have a 225 bobcat welder wont stay running can add fuel to carberator but if i stop sparing fuel in unit stops??
The fuel pump is one of the probable faults, or the needle valve in carb is stuck in closed position.
If the fuel hose is removed at carb, it should squirt gas as the engine is cranked over. If not, look in tank to see if the screen on the barb threaded into the tank has not clogged up with debris. If it is clean, replace fuel pump.
If it squrits gas- open up the carb and check to make sure the float is able to pull the needle valve down as well as the float level setting. When the bowl is exposed, look for sediment as well.
Jan 03, 2012 | Bobcat Miller 225 Welder Generator 907209...
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
Bobcat welder will not kick down between arcs, its a model 225g
Dec 23, 2009 | Welding Tools
What do you have to remove to get to the fuel tank on 863 bobcat
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Welding Tools Logo
286 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
