Question about Frigidaire Dehumidifiers
2012 #FAD704DUD, RECALL? FRIGIDAIRE - Frigidaire Dehumidifiers
How do i factory reset the dehumdifier Frigidaire FAD704DUD
Hello Roberto, thanks for your post!
From the information you have provided you would like to perform a factory reset on your Frigidaire dehumidifier. The best way to reset your dehumidifier is to disconnect power from it for at least ten minutes. I hope this information is helpful to you. -Matt
Jan 18, 2016 | Frigidaire FAD704DUD Dehumidifier
The bucket fills up but we have to put a towel down because it leaks all over the floor. What could be wrong ?
Good Afternoon Friend,
I understand that the bucket fills with water and overflows on your Frigidaire dehumidifier, model# FAD704DUD. Please make sure your dehumidifier is installed on a level that will support it with a full bucket of water. If the dehumidifier is moving when it fills with water then this could possibly be the cause of the bucket overflowing. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
Hello , I have goldstar dehumidifier model #DH40 . It's freezing from back grill? Can you please give me some solution to it? Thanks for you're help
It sounds like not enough air flow. clean the filter. I would suggest unplugging it and let it set for a day to dry out then replace filter and clean the air path including coils.
Jan 10, 2014 | Frigidaire FAD704DUD Dehumidifier
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
Unit will NOT stop running when tank is removed
There is an interlock switch in the tank area which prevents this. The interlock is either damaged or malfunctioning
Aug 29, 2013 | Frigidaire FAD704DUD Dehumidifier
My dehumidifier model number FAD704DUD is blowing hot air. What is wrong with it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 09, 2011 | Frigidaire FAD704TDP Dehumidifier
Dehumidifiers Logo
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
