Disarm TDS FCC ID: ELVAT5G Keyless Remote Control Entry
Don't use it anymore, but recently it set itself on.
  • 449 Answers
SOURCE: keyless entry wont work
check your fuses its locate under the driver side under the steering column.
Posted on Dec 17, 2008
  • 33 Answers
SOURCE: remote keyless entry not working
KEY FOBS FOR THIS MODEL MUST BE PROGRAMED USING A TECH 2 SCAN TOOL SO IT MUST BE DONE AT THE DEALERSHIP FOR ABOUT HALF HOUR LABOR HOPE THIS HELPS
Posted on Mar 28, 2009
SOURCE: set keyless remote for Nissan xterra
Key Fob Programming instructions...
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Posted on May 13, 2009
tiresmoke
  • 68 Answers
SOURCE: 1998 Chevy Camaro - security
My camaro do the same, think i paid round 40 for a replacement remote. With all doors closed try cycling the ingitoin 9 times to reset the light. This might help you bypass and disable the alarm. Turn the key to the run position, off postiton and remove the MAIN RADIO FUSE, than turn to acc position.after you done that hit the door UNLOCK switch until it CHIME ONCE, the alarm system should be off/disable. Turn the ignition to the off position and put the RADIO fuse back in. Hopes this helps
Posted on Mar 01, 2010
SOURCE: Lexus 1994 LS400 remote key won't work
also check the 30 amp fuse which says door beneath the left drivers's side near the foot rest.
Posted on Apr 06, 2011
My fcc id:nahrled4 remote starter is not working just changed the battries
You may have lost the memory or the battery is dead(might be) or incorrectly installed. Sometimes you have to check the little contacts to for proper tension against the correct points of el trans.
Nov 06, 2013 | 1401 Remote Start/Keyless Entry System
MARS OMEGA# 343-02 FCC ID:M65NVT504 TRYING TO FIND OUT MAKE AND MODEL OF WHAT CAR THIS WAS INSTALLED IN. THANKS FOR YOUR HELP
This remote came with the MARS-22+. It is a universal type of keyless entry with remote start unit. It did not come with any particular vehicle, since it can be installed in almost any vehicle.
Dec 27, 2010 | Omega MARS-22 Remote Vehicle Starter with...
I have a older unit it has keyless entry bought in the 90s it quit working. untill recently car started by it self probly from another remote interferance how do i diagnose it?
reprogram the remote to your car 4 times, this way any other remotes programmed to your car won't work anymore, because the unit only holds 4 frequency's
Dec 16, 2010 | Remote Starter with Keyless Entry
How to reprogam this model pursuit fcc id: elvatrbb part no5bcr05
Turn the ignition on, press and release the programming switch three times, press and release the remote button. Turn off ignition, test system.
Sep 22, 2010 | Car APS921 Remote Starter - Keyless Entry
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
Hi. Do you what the FCC ID is for the Nissan Versa (Tiida) 2006. I am trying to purchase a new keyless remote. Thanks. RJ
I believe that with most keyless entry systems, you must buy the remote specific to Nissan Versas, and then either take it to a dealer to have them program your in-car receiver to understand the new remote signal, or download the instructions and add it yourself. FCC ID should have absolutely bearing on this.
Dec 04, 2009 | 2006 Nissan Versa
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
