On new installation I cannot get channels - Televison & Video
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
Installing channels
Go to the initial setup for your TV which should be selectable using your new remote control.. Select the option to search for active channels in your area.
Jan 25, 2014 | Televison & Video
Gooman ld2667d tv is not recieving any digital channels, using the same ariel port as before. unplugged the tv to put onto a new stand and getting no digital tv channels. Signal is 0 % too. Before i...
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Aug 12, 2011 | Goodmans 289NS 14" TV
I have got a new Toshiba Regza I have tuned it in but don't seem to have got all the channels can u help
you will need first to configure the antenna sources where you want to program channels. and then you can add channel through your remote control. to add channels in the channel memory, first press MENU and open the set up menu and then highlight installation and press enter. a new set of installation menu icons will appear on the screen. open the terrestrial menu highlight channel add, and then press enter. the list of channel program from the antenna source that you select will appear on the screen. to add now a channels to the channel memory, highlight unchecked box next to the channel number you want to add, and then press enter to check the save new settings highlight done and press enter.
Apr 19, 2011 | Toshiba Televison & Video
Have just purchased new toshiba tv with freeview but can only get channels 1 to 5 on it
When installing the tv channels, the system must search for analogue and digital channels. It sounds as though it didn't complete the installation procedure.
Let it try again.
Hope that helps.
Dec 31, 2010 | Toshiba Televison & Video
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
