The printhead compartment sticks, doesn't slide back or I have to lift ink cover to get it to adjust.
  • 511 Answers
Turn on printer, and unplug power while carriage moving. Then move carriage by hand freely.
Posted on Jul 25, 2009
Have verifone 801 printer - prints game and fish licenses - how do I change the printer ribbon
NOTE: The inside cover of the printer has medialoading instructions for vendors.
  1. Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
  2. Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
  3. Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
  4. Slide both ribbons off the hubs, and discard them into the trash.
  5. Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
  6. Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
  7. Insert the supply hub/ribbon into the rear spring-loaded spindle.
  8. Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
  9. Continue past the Printhead, and over the 3rd aluminum roller.
  10. Insert the take-up hub into the spring-loaded spindle 'star' hole.
  11. Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
  12. With your other hand, lower the Printhead Carrier to its locked position.
  13. Close the printer lid.
Oct 19, 2013 | VeriFone Office Equipment & Supplies
A605s (Printhead cannot move). And I have not found any obstructions. The printhead is over to the left and I cannot get it out.
The error could be due to an outdated firmware. Please follow the steps below to fix the problem:
1. From the printer control panel, press the Setup button > Maintenance > Replace Printhead, or for touchscreen panels, touch Ink Levels > More Options > Replace Printhead.
2. Open the printer cover. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Press the tab, and lift the latch. Pull up to remove the printhead. Close the printer cover then turn off the printer/unplug the printer from the power source.
4. Turn the printer back on. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button or the Home icon for the touchscreen panels. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to Lexmark S600 Series Firmware Update.
6. Once the firmware update is successful, firmly re-insert the printhead.
If the error continues to display on the screen, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark Interact S605 All-in-One Color...
How do I remove the print head on a Cannon Pixma iP90V Thank you for any help you can provide.
You turn the machine on. Open the top cover an allow the printhead to slide to the center position. At this point turn off the machine..By hand move the printhead to the right slightly....you can be a little forceful. There is a green tab on the frame or retainer of the printhead that you push to allow it to lift and the entire printhead should come out!....If ink is still in the print head carriage it will come out with the printhead.
Oct 19, 2010 | Office Equipment & Supplies
Brother MFC-410CN
When you lift the scan assembly you will see 2 covers that run to the back of the machine, you lift those covers and unplug the cables from the circuit board and take this scanner assembly off. After that there are 7 screws to lift the center cover. You will then see the printhead with 4 ink tubes attached. Cleaning usually doesn't help this printhead, only a new printhead, around $100.00
Feb 17, 2010 | Brother MFC 420CN All-In-One InkJet...
How to remove printer head ? According to the manual, since the printer has 7 orange flashes, the printhead (per manual) needs to be removed and reinstalled.Not sure how to do that.
Just like changing the ink, open the cover so that the carriage comes to the center, remove the inks, and then lift the handle on the side and lift out the printhead. Use either alcohol to wipe the contacts on the back of the printhead and the contacts on the carriage, or an eraser to clean then brush away any crumbs.
Jan 30, 2010 | Canon BJC S300 InkJet Printer
How do i remove the print head to replace with a new one
You have to turn on the machine and lift the cover to bring the carriage to the center just like changing ink. You remove the inks and lift the gray handle to release the printhead. The top of the printhead tilts forward and you lift out. The new one goes in bottom first and then tilt back and lower the gray handle to lock in. Install inks and you're done...
Dec 14, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How do i replace the printhead
The Print head is sitting in a cradle. So do not confuse the cradle with actual print head. The cradle is the one that slides left and right on the metallic rod. Do NOT try to remove the cradle.
Make sure to use genuine Canon ink cartidges.
1) Unplug the power to the printer. Remove the USB printer cable.
2) Lift open the top cover by depressing the round button on the right side of the printer; exposing the printer ink cartridges.
3)Lift the grey lever on top of the cartridges. This dis-engages the printhead electrical connections. Remove all the 4 ink cartridges from the printhead. From the cradle hold the printhead from the top and lift the printhead by tilting it toward you. Make sure not to touch the electrical contacts in the back printhead.
4) Take a small plastic bowl and fill it with 1/4 inch or less with Rubbing Alcohol(70% Isopropyl Alcohol). Dip the bottom of the printhead in the alcohol. Soak printhead in the alcohol and shake it lightly so the dried ink clogging the printhead can come loose. Us paper towels to soak excess alcohol from the bottom of the printhead. Make sure not to damage the printheads.
5) Pour some alcohol from the top of the each inlet of the ink cartridge seat and again soak up any excess alcohol with paper towel. Let the print head dry up little.
6) Put the printhead back in the cradle and insert back the ink cartridges in their right seat. Lower the grey lever back into its position so the electrical contacts are made on the printhead.
7) Plug the power and USB port.
8) Print a picture or diagram with color in draft mode. You might have to do this couple of times, so that the inks starts flowing from the ink cartridge through the print head. Then print the same in high quality. If the heads are unclogged your printer should work as new.
Just one bit of advice: you may wonder if you've got the position right because the grey lever may not seem to be able to engage - it will, but needs a fairly strong push to click into position again.
Oct 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Dec 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Unsticking the C2424 Printhead
You need to remove the scanner and document feeder.
to do that you disconnect the molex connector from the right side of the printer next to the power cord.
Then remove the 2 screws on the upper part of the back of the machine, one each on the 2 side covers. That is all that holds the covers on. Now, step to the side at about the middle of the machine, lift up and out on the one of the side covers, Now be ready because the front cover will "pop" off also, that front cover holds both side covers on in front.
Now you need to go to the back again, there is a small white cover on the upper back about 10 inches long and 2-3 inches on top and down the back, remove it and the metal cover underneth it.
Last you have to remove the ink holder, where the solid ink stick are placed. There are no bolts holding it in, just a couple of plastic tabs on the sides, You need to release them with a small screw driver and lift it out, There are 2 connectors on that plug in on the side of the machine. Once you get the ink loader ( holder) off you have accessed the print head area. It really is pretty easy to get to. Just sounds like a lot, In actuality, it takes about 10 minutes. Make sure you have either some magnetic Torx drivers or a 5.5 MM nut driver to remove the screwws.
May 22, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Have a cannon mp730 multipass screen shows wrong cartridge cartridges are ok ?
MPC730
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE [set]. 3) Select [8] PRINTER TEST in TEST MODE 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
If the printheads are badly clogged and the printer driver cleaning cycles aren't fixing it, you may try the
following:
First effort: put a few drops of cleaning solution onto the park pad "sponge". This is that sponge-looking thing
(actually a hard plastic foam) where the head sits when not printing. Just do whatever it takes on that printer to
unpark the heads as if you were going to change cartridges, then close it up and let it sit for a day before you
run a cleaning cycle and nozzle check again.
Extremely Thorough Cleaning: Take the head out, remove the cartridges. If you've saved the orange seals, tape them
onto the cartridges, if not then wrap black electrical tape around so it covers the ink outlet and the little air
inlet on top. Only pull it snug across the ink outlet, not tight, and fairly loose on the cartridge body to prevent
tape creep.
I then just stick the head under a stream of hot tap water. I use a soft plastic eyedropper to squirt the above
cleaning fluid into the ink inlet meshes on the head and to flush ink off the bottom of the head. Careful not to
touch the nozzles!
As you squirt cleaning fluid into the screen, a lot will rush back out, that is fine as it is flushing ink and gunk
back out rather than forcing it through the nozzles, which are far finer than a human hair.
When you see little or no more color in the water or cleaning solution, force some of the straight
filtered/distilled water into the screens. Rinse the outside of the print head with straight isopropyl alcohol (99%
is better than 50% for this) and pat dry with a clean cotton towel (-not- paper towels) and again, DO NOT TOUCH THE
NOZZLES.
Patience is a virtue. I've bought a lot of Canon printers in thrift stores with full cartridges because the heads
clogged, they bought new cartridges, that didn't fix it so they tossed it at Goodwill. I clean them up and for
$12.95 I get $45 worth of brand new cartridges and a backup printer. I only had two heads be unsaveable, those
would print on all nozzles but had sprung internal leaks between two colors, cyan and yellow. The symptom was
yellow nozzle checks print green, and the ink inside the yellow cartridge slowly turns green.
Re: Removing Canon MP730 Printhead  Please try at your own risk -- A word of caution: The Print head is sitting in a cradle. So do not confuse the cradle with actual print head. The cradle is the one
that slides left and right on the metallic rod. Do NOT try to remove the cradle. Here is the link to canon to get
some guide:
http://64.233.167.104
1) Unplug the power to the printer. Remove the USB printer cable. 2) Lift open the top cover by depressing the round button on the right side of the printer; exposing the printer
ink cartridges. 3)Lift the grey lever on top of the cartridges. This dis-engages the printhead electrical connections. Remove all
tilting it toward you. Make sure not to touch the electrical contacts in the back printhead. 4) Take a small plastic bowl and fill it with 1/4 inch or less with Rubbing Alcohol(70% Isopropyl Alcohol). Dip the
Make sure not to damage the printheads. 5) Pour some alcohol from the top of the each inlet of the ink cartridge seat and again soak up any excess alcohol
with paper towel. Let the print head dry up little. 6) Put the printhead back in the cradle and insert back the ink cartridges in their right seat. Lower the grey
lever back into its position so the electrical contacts are made on the printhead. 7) Plug the power and USB port. 8) Print a picture or diagram with color in draft mode. You might have to do this couple of times, so that the inks
Apr 02, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
