Question about Yamaha Audio Players & Recorders
Panasonic tv Yamaha sound bar but when sound bar is on the voices are echo sounding
  • 575 Answers
Check your manual. You should have different settings for different applications. The echo may be set for music listening rather than TV listening.
Posted on Apr 27, 2017
Open SKy
  • 620 Answers
SOURCE: Can't hear voice of singer on speakers, more of an echo sound
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
Posted on Dec 26, 2007
SOURCE: sound echo
If you have the DVD going through your stereo to produce better sound, you could be getting an echo effect by also having the volume on your TV turned up. So a possible solution if this is the case, is to simply turn the tv volume down so that the only sound you are hearing is coming from the stereo.
Posted on Jan 14, 2008
bob_computer
  • 3153 Answers
SOURCE: skype sound test
This means you need to tweak the volume levels a little and maybe also change the recording levels.
Echo is a common thin with VOIP communications and it may not go away fully but tweaking your levels shoul minimise it.
Also do not use VOIP type communications on low speed connections
Posted on Aug 11, 2009
chanddra2009
  • 615 Answers
SOURCE: echo occurs on voice chat
Dear madam,
It seems to be problem with web cam mic, turn off your speaker, if your speaker is loud it also creates a echo effect so better choice is use headphones having mic for chatting or conversion purpose, now you can hear voice clearely and your voice also clear to the listener.So solution is better to use head phones it may cost about Rs 250.00. I think it definitely solves your problem.if you have any problem regarding this issue leave a feed back,we will glad to assist you.
good luck
Posted on Sep 08, 2009
walesarumi
  • 6993 Answers
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
Posted on Feb 26, 2011
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
I can not get any sound from my yamaha sound bar
does the tv have optical out or coaxial out this is your only option for this sound bar.
Jan 18, 2014 | Yamaha YAS-101 Front Surround Sound Bar...
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
Sound on pc ( Vista )echoes and indistinct works on device and other pc's
I think all sounds to be going mute go to control panel - sounds options & go to volume tab - then advanced - then increase all the volume bar.
I think it will be helpful if the problem is this.
May 29, 2009 | Audio Players & Recorders
Speakers sound tinny
Did it ever work right? When did the problem start?
Echoes:
There are many DSP modes with this unit. Echoing voices is probably one of them. This is a user setting. Look at the front panel for information regarding that. I imagine the Straight/Effect button might change it.
Have you read the manual and followed the specific menus for setting up the DSP modes?
Screeching, Scratchy Sound: I don't think this is related.
Did it ever work right? When did this problem start?
Is it from all sources? All channels? All DSP modes?
I need more to information be helpful.
Mar 21, 2009 | Yamaha HTR-5930 Receiver
Sound echo
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
Oct 20, 2007 | Audio Players & Recorders
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
