Question about HP Office Equipment & Supplies
My hp officejet 7510 is not printing instead its showing ox610000fc
checkitright
  • 1362 Answers
SOURCE: hp officejet r45 Printer
hre is the link if you did not receive it yet
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=61561&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Dec 13, 2007
hvpatel
  • 152 Answers
SOURCE: printer hp officejet 7310 all-in-one
there is not your printer problem but printer print only html page contain
Posted on Feb 28, 2008
Khalsa007
  • 79 Answers
SOURCE: HP Officejet 5610 All-in-one printing in red instead of black!
Hi ,
As you have already tried replacing the ink cartridge , u can try to reset the printer .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Note - you can also try the Ok n cancel key combination in place of # and 6 .in case the first combination does not work .
Thanks
Posted on Jun 04, 2008
  • 71 Answers
SOURCE: HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Posted on Oct 20, 2009
  • 5264 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
How to Fix HP Printer Error Message 0xc19a0035?
Hi hptechnicalsupportnumber , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Which model printer do you have?
Did you recently change ink cartridges?
Did you perform other cleaning or maintenance?
Is the printer old, or possibly new enough to still be under warranty for free repair?
Examples of web pages with information on fixing this error:
https://h30434.www3.hp.com/t5/Inkjet-Printing/Officejet-7612-Printer-Failure-0xc19a0035/td-p/6417241
https://support.hp.com/us-en/product/hp-officejet-7510-wide-format-all-in-one-printer-series/7127198/model/7127199/document/c00489814
http://www.en.rellenadodecartuchos.com/2015/07/how-to-solve-0xc19a0035-error-problem-of-printer-or-ink-system.html
Jan 30, 2018 | HP Office Equipment & Supplies
My HP photosmart 7510 does not recognize the presence of any color cartridges. I use only HP 564 cartridges. It prints only black. What can I do with it?
Check this link for ink cartridge problems. The part on "older generation cartridges" is very interesting. It is located on page 39 of the manual (page 40 of the pdf).
http://h10032.www1.hp.com/ctg/Manual/c03011756.pdf
Jan 06, 2015 | HP Photosmart 7510 e-All-in-One Printer
How do I replace the ink cartridges in my H711n printer?
Please follow the link will show how to change :
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/1655134310001/replacing-a-cartridge---hp-photosmart-7510-e-all-in-one-printer-c311a/video/
Mohamed Hejazi
HP TECH. SUPPORT
Afaqnama - Tripoli - Libya
Mar 18, 2013 | HP Officejet 6700 Premium e-All-in-One...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
I have the HP Officejet 6210, it prints but will not scan
If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
Dec 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Our HP Officejet 6210 All-in One is printing only black and white. The test page prints color blocks. Is there a setting that I can adjust?
yes when you give print command you can choose the option in printer propertis colour mode instead of grayscale.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Envelopes won't print
where do i insert envelope to print address?
Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer hp officejet 7310 all-in-one
Nov 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Ben Johnson
