Plded4243a-uhd has blue screen.put 3 new boards in.t-con,power,main from shop jimmy-still blue screen. what could be wrong?
  • 160 Answers
SOURCE: MAG 3200 Lcd TV I
Hello.
Normally T-Con board have nothing to do with powering up of TV. It's only affecting image when TV is on. So we can discard T-Con as a suspect for now.
Remove "new" main board and install the old one. If TV powering up and back light comes on - you've purchased defective Main Board and you should return it for exchange or refund. It happens all the time, boards that they sell most of the time are refurbished and sometime nothing was done and they send defective board to the other customer by error.
In case that TV is not powering up even with the old main board - look for something that you have done during replacement (like forgotten or overlooked connection, broken/bended pins etc.).
Russ.
Posted on Aug 28, 2010
  • 131 Answers
SOURCE: Viewsonic N2635W. Did not turned on. I replaced
You should also replace the cable that connects the main board with the control button.
Also replace the control button main board(a motherboard with all the buttons)
For example look here. It should look like this http://www.interliquidparts.com/wp-content/uploads/wpsc/product_images/IMG_6420.JPG
finally replace the ribbon that connects it to the main =board since these are the only important things that could still cause the problem you have.
Please rate if this helped you.
Posted on Apr 19, 2011
  • 362 Answers
SOURCE: My Vizio 55XVT1A power on, has sound, but no picture. I changed new power board, main board, T-cond board, but it still same problem. What's wrong with it? Is it anything with inverter board? Than
If this is an LCD tv the backlight inverter is bad, a good way to check it is to shine a flashlight close to the screen and see if you can see a faint picture.
Let me know what you find
Posted on Feb 19, 2012
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
chapelure09
SOURCE: Hannspree 28 Inch Lcd Tv Model Number HSG1075
Stop buying hot TVs folks. If you bought it legit, you can take it back.
Posted on Oct 23, 2013
The answer to my question was to replace the T-Con Board. Looking at Shop Jimmy the only board for this model is BN44-00801E Power Supply/LED Driver Board. Is the T-Con board embedded in this board?
The T-Con board is embedded in the main board and not in the power supply/LED Driver board.
The Main board part number should be BN94-09124C but I would suggest to do more research or call Samsung for more info.
Sep 18, 2017 | Samsung Televison & Video
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
Dec 11, 2015 | Mitsubishi LT-46144 46 in. LCD HDTV
I have sony bravia kvl40u100 it has sound no picture what could be wrong
If there is white light coming out of the back of the set, it sounds like the inverters are firing and your backlights are working. Is the screen pitch black? Gray? White? Blue? It could be a defective T-Con, main board, faulty power supply rail, or in rare cases, a faulty LCD panel.
Jan 05, 2013 | Televison & Video
Sharp AQUOS LC-26SH10U 26 inch LCD Television. Video input problems? No audio. I get a picture using RCA cables but nothing using coax cable. Also I have no audio. When I get a picture using the RCA cables...
You need to replace Main Board of TV to fix its issues, click Shop Jimmy to see an image of that board, call Shop Jimmy on 952-881-6492 or 877-881-6492 for main board availability as currently its out of stock.
Thanks.
Jan 17, 2010 | Televison & Video
Polaroid tlx-3210b tv will not turn on the red light comes on and the blue light comes on when you hit the power button but still no picture or sound have to unplug tv to turn off blue light. contacted...
Symptom shows that Mani Board is bad in your TLX-03210B Polaroid TV and need to be replaced. I do not see problem of capacitors in power supply board. Problem seems in system control section of TV that is located on main board.
Click Shop Jimmy as it is best source to obtain boards of LCD TVs.
Please call Shop Jimmy for main board availability as currently its out of stock.
Hit "add a comment" button for further query / info.
Thanks.
Apr 30, 2009 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
