What is the bubbling noise from my green star Ri boiler on my central heating system
System working ok serviced four weeks ago.
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
SOURCE: Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
Illeagle
  • 525 Answers
SOURCE: Where can I get a free Central Boiler owners
www.managemyhome.com usually is a great place to find users manuals
Also www.homemanagement.services.officelive.com
has numerous other website links posted that may be of help.
Posted on Jul 16, 2009
shastalaker7
  • 1515 Answers
SOURCE: Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Posted on Oct 31, 2009
  • 234 Answers
SOURCE: New grundig pump is now making a kind of clicking
I was ready to pass your question and go to the next person because you said it was making a clicking, and I could not relate or diagnose that type of sound for that kind of pump. Thank God I decided to read to the end where you said rattling sound. that is what you should have said in the beginning.
1st, did you replace the pump cartridge or the whole pump unit? 2nd, is the pump in a different oriented position than the original pump position? The inner cartridge floats inside the pump as it rotates and if it is in an oriented position that allows it to bounce (to & frow) it will make this rattle sound; not serious but can be annoying. It is was a replacement cartridge, perhaps the new gasket and the old gasket are in place, thus allowing too much space for the cartridge and it therfore moves too much and rattles. Or, if it was replaced as a whole new unit. there is a problem with it that you should not be responsible for, except for the positioning orientation. Finally, if there is still too much air in the system, the air bubbles will jossle the cartridge untill you get rid (bleed ou ) the remaining air. Goodluck<Macgivor
Posted on Jan 02, 2010
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
Elite 50 boiler
There should be a pressure drain to purge out all the air. Sound like there is an air bubble in the system somewhere.
Jun 03, 2013 | Water Heaters
Radiators not getting up to temperature
depending on the piping configuration; Series loop or mono-flow, you might need bleed the system. If its a mono-flow you would have bleeders on the radiators. Bleed them only till you you have water coming from the bleeders. If its a series loop, you need to bleed them from the area of the circulator by the boiler. There is a urge system you need to use and see if you can get the information on how to do that. I would think that somene here as written a tip on how to purge a series loop hydronic system. Also check to see that you have somewhere in the 12-15 PSI on your system pressure.
Dec 14, 2009 | Desa International CBN30T Central Heating...
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
I have a multifuel stove which runs my central heating system from its back boiler. When it gets really hot there is a loud clicking and knocking sound from the rear of the stove where the thermostatic...
That clicking and knocking noise you hear is called cavitation. It's when the bubbles of steam are cooled down rapidly and implode upon themselves. Cavitation is not a good thing to have in a boiler as it can cause dramas. This cavitation is more than likely because the boiler is firing too hot. A service technician should be called to turn the regulator down a little bit.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
