Question about Garden
Wizard lawn tractor transmission belt is slipping how do I tighten it
    Master:
  • 604 Answers
Get a new one yours is stretched
Posted on Apr 27, 2017
Testimonial: "it is a new belt.This mower has been cutting around two acres for the last 14 years so its really worn."
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Murray 46581X92A. Does not go up a hill. Seems like something is slipping. Mowes okay on level ground.
Could be the drive belt is slipping. This is the belt that goes from the engine to the transmission. If it is worn it can slip. You can go to this link and view parts.
http://www.ereplacementparts.com/murray-46581x92a-2000-4634-lawn-tractor-parts-c-17887_17888_28185.html
It refers to the belt as ITEM 15. Belt, motion drive
Oct 13, 2010 | Garden
Transmission belt slips, can it be adjusted to tighten
You can replace the drive belt, and make sure the springs on the tensioner and clutch pulleys are good, but the belt itself has no adjustment. They stretch a bit with age, also not uncommon for the transmissions to go bad which means slow or no movement even though the engine runs normally.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
