Tub keeps locking itself - Washing Machines
    Master:
  • 604 Answers
Set the lock to unlock
Posted on Apr 27, 2017
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
Dec 18, 2014 | Jilong Inflatable Hot Tubs: Prompt Set...
Haier hlp23e jolting noise spin
You need to level it again. (the knobs on the bottom of it are threaded so you can adjust them to make them level, it can be time consuming, so it is best to start with the one that is shortest.
Mar 23, 2014 | Haier HLP23E Top Load Washer
I have a whirlpool cabrio model wtw6600sw0 ans my washer tub is unbalanced and rocks bad. i have leveled the machine and evenly distributed the load! could there be something wrong with the tub or...
after you leveled the washer did you turn the locking nuts on the legs up against the bottom of the washer cabinet to keep the legs from vibrating back out of level?if you dont lock them they will change height during spin
May 06, 2012 | Washing Machines
Spim cycle keeps turning off and on and overheats the motor keeps turning itself on and off until it shuts down
There could be many reasons for this. Check the tub to see if the tub spins freeley by hand, any rubbing noises? there could be a stuck break, or the drum sometimes falls and rubbes the tub, you can tell this if there is a lot of space 1/2" or more under the agitator. The motor could be worn out. How do you know that the motor overheats?
Sep 30, 2011 | Roper Washing Machines
I presssed lock on my hot tub and now nothing will workk
You have engaged the system lock by pressing the lock key on your control panel. You will now have to either enter a code or press certain keys in a certain sequence to unlock the system. If you still have the manual for your system you will want to lookup locking the system to see what the default way to unlock it; if you don't have the manual you will have to contact the place where you purchased the tub from and have them tell you how to unlock the system. You might want to try and power down the tub completely, wait at least 1-2 minutes, then turn it back on. It's possible that the system might reset itself and your control panel will unlock.
Feb 19, 2011 | Sport & Outdoor - Others
I have a one handle shower/tub faucet, and when you run straight hot water (to preheat for example) the water shuts itself off. Lever is still in the lifted/on position however. Cold is fine, even warm...
If this is a newer valve what is probably happening is the valve is a scald guard valve and is shuting itself off when it senses no pressure on the cold side. I don't have a lot of experience with am. std. valves but I'm sure you can get instruction on line to set heat setting on valve higher. Thank you.
Jan 20, 2011 | American Standard One Handle Tub & Shower...
The kneader and pan keep falling off the track as it's kneading the dough, why? Just bought it 2 weeks ago first time using it.
the tub needs to be locked in to place to keep it from slipping off, usually you put the tub in slightly turned then once it's seated give it a slight turn so that the sides are even, try pulling the tub straight up if it holds the you should be able to get it to make a decent loaf of bread...oh yeah by at an angle it usually needs to be slightly counter clockwise from even...hope that helps
Dec 05, 2009 | Refrigerators
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
The 13/16 nut that holds the tub down keeps falling off
II suspect it is bad design, imagine that. We are having the same problem. After replacing the nut and using lock tight on threads, it worked two days and loosened again. My next attempt will be to "stake" the nut in place. This involves using a chisel and hammer to lock the nut in place by deforming the nut and shaft with a 90 degree dent. A second alternative will be to drill and install an allen head screw to lock shaft threads to nut.
Dec 14, 2008 | GE WJSR2070B Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
