Question about Nikon Coolpix S51c Digital Camera
Nikon coolpix S51 camera with 2GB Ocz card. Card works fine in the camera and PC can read fine from the camera thru USB connection. But when I put the card in card reader Windows XP sees the card but says that it is not formatted and asks if I want to format it now. Nikon transfer does not see the card either. Should I format it in Windows first and then use it in the camera?
  • 33 Answers
Try formatting it w/ windows first the try it in the camera, if it wont work, the camera & your computer might be using a different file formats
Posted on Jul 25, 2009
For some reason when I connect my Nikon Coolpix S51 to my Macbook the device is not recognized. I have connected it, using the same cord, to my hp desktop and it connects and is found immediately. Any...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.
Aug 15, 2010 | Nikon COOLPIX S51 Digital Camera
COOLPIX S51 Digital Camera: I turn the camera on then connect it to my Mac via...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
May 16, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
Nikon coolpix s51, lost the adaptor for connection between laptop and camera. where can i get a new one? friend has a nikon coolpix as well. cant understand why his cable doesn't fit.
Nikon usually uses a standard fitting , but there are now 5 or six different "standard" USB tips (see Wikipedi article about USB if you want pictures. GE makes an adapter cable with interchnageable tips. You can also get the replacement cord thru any Nikon dealer (if they are willing to order it for you), But my personal choice is to get a digital media card reader instead and remove the card from the camera and read it thru the card reader- multi format card readers can be bought at office supply stores for under $20 and sometimes OfficeDepot puts their Aptiva brand single format card readers on sale for $5
Aug 24, 2009 | Nikon Cameras
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
I have a nikon coolpix L20 and HP memory card.
hey you can put your photos from your camera to your computer and view it directly but if you want to do the vice versa(i.e computer to camera) if you just like that copy the photos from your computer and paste them in your device's memeory then you cannot view them . instead you have to install the picture package transfer from your installation cd(may be a different name for nikon software) and then connect your camera via usb. open the software you installed then you should transfer the photos to camera from computer via the software only. this happens because your camera is an embedded system and its not a computer.for your information hp and nikon have nothing to do with this issue..
Jun 25, 2009 | Nikon COOLPIX S51 Digital Camera
Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
Not sure if this helps, but it worked for me on a Coolpix 5000.
I tried a 4Gb card, and the camera formatted it and reported out-of-memory. The problem seams to be that that max 2Gb is supported
What I did was partitioned the card into 2 sections with 2Gb on each. I then formated them to FA16.
This worked - but you can only use half of the card (i.e. 2Gb)
For the tools I used a Linux laptop with CF reader. The tools are build in here (fdisk and mkdosfat). I don't know how to do it on windows.
May 18, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix S51 - unable to install software on Window ME
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Dec 06, 2007 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51c Digital Camera Logo
75 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
