Question about Bosch 24 in. SHU53 Built-in Dishwasher
BOSH DISHWASHER SHU5300: DOESN'T DRAIN COMPLETELY, WATER DOES NOT SIT ON THE BOTTOM BUT POOLS UNDER THE FINE FILTER. THE WATER HAS A BUILD UP AND THEN BEGINS TO SMELL. UCK!! I HAVE DONE ALL OF THE CARE & CLEANING POINTS FROM THE MANUAL. THE DRAIN HOSE DOES NOT HAVE AIR GAPS, THAT ISSUES WAS ADDRESSED. PLUS SEVERAL OF THE BUTTONS DO NOT WORK. THE BUTTONS DEPRESS BUT DO NOT FUNCTION. BEGINNING TO QUESTION IF I SHOULD REPLACE THE DISHWASHER? (10 YEARS OLD) THANKS FOR YOUR HELP!
  • 52 Answers
Def replace .....time to put the old girl down ....whirlpool is a good choice ....or another bosh
Posted on Jul 25, 2009
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The water is not draining from the bottom of my fdb2810ldc1 dishwasher
Hi
Daniel
Aug 11, 2011 | Frigidaire 24 in. PLD2850 Built-in...
After dishwasher run through it's cycle, the water does not drain properly and remains in bottom of the dishwasher
Hi
Daniel
Aug 10, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
This is a very good web site. Thx for pulling it
It is possible the check valve is sticking causing sour water to come back into the washer. The check valve is located where the drain line connects to the back of the dishwasher. Also make sure the drain line is higher than where the line connects to the drain under the sink. Most washing machines have a loop built into the line but it helps it to drain better when the line is higher. Try hooking the line to the top of the cabinet under the sink if possible.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher won't drain
the tech that came out may have pinched the drain hose when he put the dishwasher back in place. disconect drain hose from under sink. put dishwasher in cancel/drain mode see if water is coming out at a trickle if so, hose is probably pinched behind dishwasher
Nov 19, 2007 | Dishwashers
Bosch 24 in. SHU53 Built-in Dishwasher Logo
311 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
