Question about Stinger Camping, Backpacking & Hiking
Dropped stinger flashlight, it stopped working. Using a paper clip, I connected bottom of the battery to flashlight housing, and now works fine. Why did that make flashlight start working again
    Top Expert:
  • 12,962 Answers
You completed the circuit to ground.
Posted on Apr 27, 2017
The battery of my 2009 Ajs JSM 125 is not charging, how do I check the rectifier?
Find the rectifier. Use a paper clip (you will need two paper clips), a D battery and a single flash light lamp. Test that the lamp will light using your battery and the paper clip. Straighten/bend the clip in a manner that will allow the bottom of the battery to be connected to the side of the lamp. The solder joint on the bottom of the lamp touching the bump on the top of the battery. Disconnect the rectifier from the circuit. Put the light in each position of the four contacts using the paper clips, battery and lamp. The lamp SHOULD light in one half of the connections and should NOT light in the reverse positions. Your Bridge Rectifier is built using diodes. These diodes pass electricity one direction but not the other. Your D battery represents the electricity - the light tells if the power is passing or not. A rectifier is necessary because the Alternator on your motorcycle produces AC current. Your Battery needs DC current to charge. The diode more correctly assists in the 'creation' of rectified AC that looks and acts like DC the battery can use.
I hope this helps you.
Aug 23, 2013 | 2010 AJS JSM Trail 125
I have a stream light flashlight that will not charge. When I put it in the charger the red light on the charger will not stay on. Will blink on and of a little if I move the light around a bit. Do I need...
Sounds to me more like a connection issue at the charger due to the fact that it comes onn as you move it. However if you move it and it comes on for a second, then you move it again and it does the same thing, you are just making and breaking a connection making the charger start over, then it senses a bad battery and quits. If the battery is old it could well be that. Also look at the connection points on the flashlight and charger they should be nice and clean. A pencil eraser works great for cleaning them.
Jun 11, 2011 | Stinger Streamlight 75000
My streamlight stinger xt flashlight won't charge in the holder, however, the second battery does charge in the "piggyback"
Could be a lamp holder or charger problem. I suggest going to Streamlight's website and find an authorized service center in your area or send it to the factory for repair.
Mar 28, 2010 | Stinger Streamlight XT Rechargeable...
Flashlight problems
streamlights have lifetime warranties. Contact them to find a dealer that can fix it. They might even let you send it in to get fixed.
Aug 15, 2009 | Streamlight Stinger XT DC, Black
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
Apr 05, 2009 | Stinger Streamlight 75000
Stinger xt malfunction
If the charger indicator works i would buy the battery and the bulb and replace them at the same time, as you don't know the exact condition of either. Say you bought the battery and it worked fine for a week or so and the life of the bulb ran out ?. Tricky buys on e-bay.........
Nov 19, 2008 | Stinger Streamlight 75000
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
Camping, Backpacking & Hiking Logo
1,250 people viewed this question
Top Stinger Camping, Backpacking & Hiking Experts
Shehu Pro
Shehu Pro
Are you a Stinger Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
