Question about Altec Lansing Audio Players & Recorders
Need Schematic for Altec Lansing Computer Speaker Set ACS45
Appears to be no input from either of the input jacks . . . Woofer circuit responds to touching input to Output Power Transistor. Similar response to the two small speakers. Might be input audio transistor problem.
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
SOURCE: altec lansing
adjust the spaker settings
Posted on Apr 09, 2009
  • 27 Answers
SOURCE: Noisy left hand power output stage. Noisy transistor? No circuit diagram.
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
Posted on May 12, 2009
Marinmeister
  • 11 Answers
SOURCE: ALTEC LANSING-VS-2521 SUB WOOFER AND LEFT SPEAKER
you probably messed something up in the subwofeer amplifier box, try taking them to a repair shop, or at the guarantee place.
another solution would be: you could try and fix them yourself but i don't recommend it.
Posted on Jan 15, 2010
7 WIRES , WHAT COLOR GOES TO WHICH PIN? 2 BLACK , 1 GREEN, ONE YELLOW, ONE WHITE, 2 ORANGE, ONE HEAVIER THAT THE OTHER
Hi Jerry
What Model....?
Using a mobile phone camera would have helped in this situation.
Before taking things apart
I'll be very surprised if someone has the same speaker system in bits somewhere
An electronics guy would trace the wire back to it's source to decide what it's being used for.
Good Luck
Review Altec lansing BXR1220 Speakers 8
Altec Lansing Avs300 PC Speakers Sub
Sep 13, 2015 | Altec Lansing Audio Players & Recorders
I need a circuit schematic for Altec Lansing amplified speaker system 121
You can always try the manufacturer but I would not hold my breath. Try to google it - that is a better choice since perhaps others have also had hassles and ................
Aug 09, 2015 | Altec Lansing Audio Players & Recorders
Altec lansing ATP4 speakers aren't working
is it possible that you may have plugged the speakers into the microphone or audio input jack on the computer instead of the speaker/headphone/audio output jack?
Apr 28, 2017 | Altec Lansing Audio Players & Recorders
Dell dimension 5150. Adding Altec Lansing acs410. Two speakers with a sub. Back of speaker has 2 inputs, a sub out, and a transfer line to the other speaker. Why two inputs? Dell has 5 jacks in this...
The speakers have two inputs for two different things, in my case I use the green input for my computer and the white one for my game consoles. You just need a 3.5mm minijack male to male cable to connect between the input on the speaker and the green jack on the computer.
Jan 14, 2011 | Altec Lansing Multimedia Computer Speakers
Ah i have altec lansing acs 45.1.the problem is i dont know how to wiring.can u pls help me.ynx
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Nov 16, 2010 | Altec Lansing ACS 45.1 Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
49 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
