My LED TV TCL 40LED has sound but no picture. When started picture flashes for a second & goes off. Please suggest if LED driver voltage of Power supply is Good?
TV Power Board number is K-PL-0A-1.I think its LED driver power output is not good. What mentioned on board is LED DC power output as 30-120V but what I got at Pin 1& 2 as 24V on LED + mentioned. Can you please suggest what's wrong in this power supply board?
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD
Posted on Apr 23, 2010
  • 11800 Answers
SOURCE: My TV has a 17pw26-1
No, the voltages are just fine. The fault must be either in the PMW itself or in the HT transformer - and the only way to fix that is to replace the entire inverter board.
Posted on Oct 19, 2010
SOURCE: ILO LCD, Power supply issue, MLT169B. 24v output is dead.
I want to know R3 value
Posted on Dec 27, 2010
I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. Still have sound & can see a picture with a flashlight shining on the screen.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 19, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Tcl led tv has power to all boards, no power light, no picture, no sound
Check its 5V standby voltage at the main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Feb 09, 2015 | Televison & Video
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
TCL TV Model: 21K77 Schematic Diagram
Aug 30, 2010 | Televison & Video
No picture but has sound
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at Use the Part or Accessory Number to locate the part.
Jan 17, 2008 | Televison & Video
Clicks but crt does not turn on
The Tv clicks and CRT comes on for a second before it goes into the protection shutdown. The LED flashes 6 times and sometimes 7 times. I checked the voltage accross IC501 as suggested in other posts and one of the votages is higher thatn it should be. thesymptom for the 6 LEd flashes suggest overscurrent and bad IC 504. I don't know how to meassure the voltage on the IC504 however as it has 4 prongs instead of three. My question is if there is something that may be causing this. Please help! I can offer you the Service manual for the KV series TV in return... you seem to be a techanical person so answer is purely technical. Clicks but crt does not turn on 1 check whether power supply out put is disconnecting h/output 2 if it is ok check hor. section that is eht is ok or not as without eht crt will not glow. check crt supply &loose connection in crt base. regards thanks
Sep 11, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
