Use pc to change values - Computers & Internet
I cashed in $28000.00 from a deposit of $25000.00 after a year how much per cent did i earn . what is the formula
Percent change=100% * (NEW value-OLD value)/(OLD value)
If the change is positive, that is an increase. If negative, that is a decrease.
Sep 18, 2014 | The Learning Company Achieve! Math &...
How to increase your Internet Connection Speed?
Go to this site to see your current internet speed:<br /> <a href=""></a><br /> <br /> Pick a server, for example: SEATTLE, WA.<br /> <br /> Remember the RESULT so that you will notice that this is working...<br /> <br /> - FASTER WEB PAGE LOADING:<br /> <br /> This tweak will help web pages load faster, it has no real effect on download speeds,<br /> just helps your pc look up websites faster thereby speeding up how fast the page loads and making web-surfing more enjoyable.<br /> <br /> Navigate to this registry entry and change the following settings:<br /> <br /> For XP & 2K<br /> <br /> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\ServiceProvider<br /> <br /> For 98, 98SE & ME<br /> <br /> HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\VxD\MSTCP\ServiceProvider<br /> <br /> On the right for ALL OS's change these entries: (ALL values are HEXIDECIMAL)<br /> <br /> DnsPriority = 1<br /> HostsPriority = 1<br /> LocalPriority = 1<br /> NetbtPriority = 1<br /> <br /> To change the value right click on the value and select modify and enter the values above.<br /> <br /> here is another one.....<br /> <br /> go to start&gt;run&gt;regedit&gt;then go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters<br /> <br /> right click anywhere in the left side of the window then select NEW DWORD, then input the dword name, after the new registry entry is made, double click it and input the dword value....<br /> <br /> <br /> dword name- SackOpts dword value-00000001<br /> <br /> dword name- TcpWindowSize dword value-0005ae4c<br /> <br /> dword name- Tcp1323Opts dword value-00000003<br /> <br /> dword name- DefaultTTL dword value-00000040<br /> <br /> dword name- EnablePMTUBHDetect dword value-00000000<br /> <br /> dword name- EnablePMTUDiscovery dword value-00000001<br /> <br /> dword name- GlobalMaxTcpWindowSize dword value-0005ae4c<br />
on Mar 03, 2011 | Computers & Internet
Change Internet Explorer Title Bar Text
To change the text in the title bar of Internet Explorer, follow the below mentioned steps.
1) Goto - [Start] - [Run] - [Regedit]
2) Guide to the given Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
3) Modify/Create the Value Name [Window Title] according to the Value Data listed below.
Data Type: REG_SZ [String Value] // Value Name: Window Title
Value Data: [Enter The Text Desired In Title Bar]
4) Exit Registry and Reboot
on Mar 03, 2010 | Computers & Internet
Insert a calculated field named % Change in Value to determine the percent change in values by type.
Assuming that the Original Value is in cell A1, and the New Value is in cell B1, then the formula for % Change pin Value is =(B1/A1)-1.Format the value in % style and you're done.Rgds,Scott
Sep 30, 2011 | Microsoft Excel for PC
Dc 7600 is no saund
You have SP3 and HD audio give this a try:
This patch is required before any of the HD device drivers are installed
1. On your PC change the CSDVersion registry key to XP SP2:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=200
2. Restart your PC
3. Install KB888111xpsp2.exeHD_Audio/kb888111xpsp2.exe and your audio driver.
4. Change the CSDVersion key back to XP SP3 again:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=300
5. Restart your PC, finalize configuration of your PC, sysprep and capture.
Simplified Directions
Goto Start>Run and type in regedit , then click OK.
Click the plus signs in front of HKEY_LOCAL_MACHINE, SYSTEM, Current Control Set, Control, and finally, click Windows.
In the right panel you will see CSDVersion.
Right click it, choose Modify.
In the highlighted input window, you should see 300. Change it to 200.
Click OK, close regedit and restart your PC. Windows will now think it is SP2 and allow you to install the UAA and your HD audio driver.
Make sure to reboot and then test your sound BEFORE, changing the value back to 300.
Then follow the same steps to change it back to SP3. Change the 200 back to 300.
Jul 22, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I computer is slow and a message that my virtual memory is low
1. Click Start, right-click My Computer, and then click Properties.
2. In the System Properties dialog box, click the Advanced tab.
3. In the Performance pane, click Settings.
4. In the Performance Options dialog box, click the Advanced tab.
5. In the Virtual memory pane, click Change.
6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
Click OK and close .
Oct 11, 2009 | E-Machines eMachines Desktop PC
I have some value in Sheet2 of an xls file. now i want to link that value to a cell in Sheet1. Hence, if theres any change of value in sheet2 it also do reflect in Sheet1
Just put the following formula in the cell you want the number to change.
=sheet2!b1 the B1 is the cell on sheet 2 or whatever cell you want to link to. Whatever you put in cell B1 on sheet 2 will automatically change on the cell on sheet one you place this formula in.
Apr 24, 2009 | Microsoft Excel 2003 (065-03992) for PC
Unlock code for Build a lot 2
I'm not sure if this is it but i found this on WIKI answers...
KJIGF...also this....
Create a backup copy of the file before proceeding. Use a text editor to edit the "buildalot.ini" file in the game directory. Find your profile name in the file. The values that need to be changed are after the "[User 0]" heading and before the "[User 1]" heading. Look for the "LevelStatus" value. A "0" indicates you have not played it yet. A "2" indicates that you have passed that level. A "3" indicates that you have completed it expertly. Change all of those values to "3". Next, change all the values of "LevelNumPlays" to "1". Change all the "CityGift" values to "1". Change all the "CasualLevelStatus" values to "1". Save the file and start the game. You can now access all levels.
Hope this helps....good luck...please rate me...the Fang
Mar 27, 2009 | HP Compaq Presario C500t Notebook
Recyclebin rename
Hi there,,
Please follow the instructions:
  1. Click Start / Run
  2. Type regedit and press enter.
  3. Open the HKEY_CLASSES_ROOT folder
  4. Open the CLSID folder
  5. Open the {645FF040-5081-101B-9F08-00AA002F954E} folder
  6. Open the ShellFolder folder
  7. Change the "Attributes" data value from "40 01 00 20" to "50 01 00 20". Once completed change the "CallForAttributes" dword value to "0x00000000" (double-click and change value data to 0). You must change both of these values to get the rename to appear.
After performing the above steps you will be able to rename the icon like any other icon. Right-click the Recycle Bin icon on the desktop and click Rename and rename it to whatever you wish.
Vipin Menon
Mar 16, 2009 | Microsoft Windows XP Professional With...
Logging on to Windows XP
hmmm.. the problem in this one is wrong registry programing..
it happend to me twice while setting computers for auto login..
the quickest and only fix in here is by re-installing your OS or re-imaging it. make sure that you are not connected to any network or internet while doing this..
while setting the auto login correctly. the only key you have to chenge is:
1.) change AutoAdminLogon value t "1"
2.)change DefaultUserName value to whatever ur username is.
3.)change DefaultDomainName value to whatever domain u are in OR if you dont have.. you can input your PC name.
4.add a new string value the name should be DefaultPassword
then change the value to whatever password u are using..
5.)add another string named ForceAutoLogon and change the value to 1.
thats it.. ur set .. close the window and reboot your pc..
May 06, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
