Question about Sharp Office Equipment & Supplies
My sharp carrsel will not work, it acts like it will, but when I press start. Everything stops working
Why my door windows stopped working completely on 1997 acura cl 2.2?
Your windows lack discipline. You should have nipped it in the bud as soon as they first started acting up. Now they are incorrigible.
May 15, 2014 | Acura CL Cars & Trucks
My sharp z55 machine stopped working... the only symbol is an "H"
im not famillier to sharp z55,but symbol H indicate that ur heat roller(fusing unit) is malfunction.it cancel by program,press clear, exposure, clear, exposure, 1,4,start,clear.
Jun 19, 2011 | Sharp Office Equipment & Supplies
My Sharp LED LC-52LE820UN HDMI ports are not working. I tried powering off the cable box, TV and PS3. Unplugged the HDMI cables, then booted all three devices. Afterward I power everything off, plugged...
This is a known problem on Sharp Aquos TV's. The HDMI inputs connect to their own sub-processor board right at the ports. This board is VERY prone to failure with just the SLIGHTEST static electricity problem - it usually starts acting up after a storm, will only go out for a couple hours, you turn the TV off, come back the next morning, and it works again. You think "OK, random problem, whatever". Then it does it again a couple months later, then it starts happening more and more until the board completely stops working altogether. The board is about $150 and is easy to replace yourself - if you've ever replaced a card in your PC computer, it's not much more difficult, just more screws. These tend to go out right at the 11-13 month point, which is awesome as far as a warranty is concerned. In short, get the extended warranty or buy with American Express which automatically doubles manufacturer's warranties with ANY electronics purchase, then replace it before the warranty is up. Good luck. (and P.S., Sharp will argue that this isn't a known problem but just do a Google search, it'll pop up all over the place).
Dec 17, 2010 | Televison & Video
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Light will not travel to the right beneath the
unlock scan by the knobe under scan unit or service scan guides
Feb 26, 2010 | Sharp AL 1631 Copier
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
On my Sharp AlL 1631 copier there is replace drum
you press c-photo,c-photo then of all light then page quantity key 7 or 6 press print key please vote me
Jun 18, 2009 | Sharp AL 1631 Copier
HOW DO I RESET TO ORIGINAL SETTING
This proseger will ram clear the machine & reset it to factory condition.
1. press the Function,9,*,8,#,7
2. Press the start key
3 Press the # or * to scroll throgh the menu till clear memory
4 Press the start key
5 Press stop key 2 times will bring you back out of maintance mode
Hope it works for you
Jan 27, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Over the range Microwave trouble
It is a door switch problem of some sort.  I have two Sharp R-1611 units that do the same thing.  The light and fan come on, but not the heat, thank goodness.
I am going to replace it since the plastic for the case and door is cracked in numerous places.  I have spent several hours researching microwaves online have not a single clue what to replace the Sharp with.  Seems like every vendor has very good units and very bad units.  I guess you just pay your money and take your chances.
Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
