Question about In Office Equipment & Supplies
8.81" is what in tenths? Please indicate exactly how in simplest form to calculate.
  • 154 Answers
Well 8.81" is in tenths, 8 is the whole inches while .81 is .01 over 8 tenths of an inch as many rulers I have seen carry tenths this would be a say half a line division more from the eight tenths point.
you may do better converting it to mm which would be 22.3774cm or 223.774mm with a simple inch to cm multiplier of 2.54 though this I think is rounded up.
If you want a non metric answer then you are in small fractions which I have not seen used much for many years in general practice 32nds 64ths and 128ths is the highest I have seen but that was many years ago.
Hope this helps...............
Posted on Apr 27, 2017
Simplest form
what is 24/80 in simplest form?
Jan 13, 2014 | Office Equipment & Supplies
Is 19/57 in simplest form
No, since 19 and 57 have a factor in common.
Even though you didn't ask, that common factor is 19. Dividing the numerator and denominator by 19 gives 1/3.
Nov 08, 2012 | Texas Instruments TI-84 Plus Calculator
How do you put it in simplest radical form for TI-30XIIS
I do not believe that the calculator is capable of displaying results with radicals. IF its is capbale of doing so, it will always display the radical expression in its simplest form.
Jan 24, 2012 | Texas Instruments TI-30XA Calculator
It is already in its simplest form because 81=9*9=3^4, and 62=31*2 do not have common factors by which you could simplify the fraction further.
Sep 22, 2011 | The Learning Company Achieve! Math &...
81 is what percent of 135
To find what percent of 135 is 81 take 81/135 = 0.6 This is only in decimal form so we times 0.6 by 100
to put it into percent. So 81 is 60% of 135.
Mar 31, 2011 | Texas Instruments TI-83 Plus Calculator
Write the expression in radicant exponent the given is square root of 81 what is the answer and the solution.
I come up with 3. (81^(1/2))^(1/2)=3. the Simplest form. I used 81^(1/2) because, 81 looks like 81 to the first power, instead of a fraction.
Jan 14, 2011 | Texas Instruments TI-89 Calculator
Answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Jan 20, 2010 | Casio FX-115ES Scientific Calculator
Different answer two different calculators ti-81 and ti89
I had the same problem when I got my first 89, even though it's really a feature and not a problem.
Press the diamond key then enter to get your answer, and it will give you the decimal answer instead of the exact answer like you have been getting. Hope this helps...
Nov 15, 2008 | Texas Instruments TI-89 Calculator
32 people viewed this question
Top In Office Equipment & Supplies Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
