Question about Dryers
The dryer gets hot then gets cold. changed the glow plug but problem still exists
  • 864 Answers
The gas will cycle on and off during a drying session in response to the thermostat. If the clothes are not drying in a reasonable amount of time or if the gas only runs for a minute or so after it ignites (after the glow plug goes off) the exhaust path may be restricted. Check to make sure the lint filter is clean and that the exhaust duct is clear all the way to the outlet. Check also inside the duct where the exhaust connects to the dryer at the back or side. If the gas goes off immediately after the glow plug ignites it then goes off, then the secondary coil on the gas valve may be bad and the coils need to be replaced.
Posted on Jul 25, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Check the thermolstat isnt covered in **** and over heating
My 2004 Diesel Kia Sorento takes 18 seconds to cold start. OK when hot. I have changed glow plugs and checked them. Injectors seem to get to pressure. Computer shows no errors. Battery is new and turn
is the air intake clear , new filter nothing squashing the intake pipe, how long does it take for the glow plug light to go out once you've turned ignition on ?
Oct 23, 2014 | 2004 Kia Sorento
I have a gas dryer and cloths come out wet
Does the dryer get hot? If so check dryer vent.
If it is cold check the gas supply. Next open the lower cover and look to see a red glowing from the ignitor when running. It it comes on and no flame then you probably have a bad gas solenoid. If there is no red glow then it is probably the ignitor.
Hope that helps
Dale
Nov 10, 2013 | KitchenAid Clothes Dryer Gas Dryer Ignitor...
The igniter glows but nothing else happends
for one thing, the glow plug may not be glowing hot enough, to light burner. if glow plug does not heat up like it should, then gas will not come out. have glow plug checked.
Aug 09, 2010 | Frigidaire GLGR331A Gas Dryer
Glo plugs don't seem to be getting hot when I hold the button down ... it will however start with star ya bastard ... once the enging is hot it will start no problems
GLOW HAS TO BE WORKING.BECAUSE ENGINE STARTED.GLOW PLUGS ARE USED ON COLD START UPS.GLOW PLUGS PREHEAT THE AIR IN COMBUSTION CHAMBER SO DIESEL FUEL WILL START TO BURN ON START UP.WHEN YOU TURN ON IGNITION SWITCH THE GLOW PLUG LIGHT WILL TURN ON FOR MINUTE UNTIL PREHEAT DONE.GLOW PLUGS WILL STAY ON UNTIL THE COOLANT TEMPERATURE GET OPERATING TEMPERATURE.THEN THEY TURN OFF.
Mar 21, 2010 | 1997 Nissan Pickup
Does not get hot I took it apart and the glow
glow plugs may look like they are working but if they are not drawing enough amperage they will not open the valve you may have bad coils on the valve this is also a common problem
Mar 07, 2010 | Whirlpool Dryers
Jaguar x type 2 litre diesel. how often should the glow plugs be changed?
Hi, glow plugs does not need changing unless the vehicle struggles to start in the morning or when cold. When testing the glow plugs, they should not take longer then about 5 seconds to become red hot.
Nov 24, 2009 | 2002 Jaguar X-Type
2000 peugeot 306 1.9 diesel smokey on startup and misfiring when cold but is ok after heating up no wAater loss any ideas
change the glow plugs i used to have a 306 and a huge cloud of white smoke come out of the exhaust on start up lol, changed the glow plugs and was clear as a whistle, its because the glow plugs dont get as hot as the others and fires up on the hottest cylinders so if you have two glow plugs out the other two are being forced to turn over hope this helps you ;)
Nov 15, 2009 | 2005 Peugeot 405
31 year old dryer the glow plug gloes but the gas will not fire
you will need to change the selinoid coils on top of the gas valve. that should solve your problem.
Oct 07, 2009 | Dryers
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
Volks jetta deisel 1997 won't start
DEPENDING HOW COLD OUT IT IS DIESELS DONT LIKE TO START IN COLD WHEATHER UNLESS THE GLOW PLUGS ARE WARM THIS IS THE REASON FOR PLUGGING DIESELS IN MOST WONT START IF ITS COLD OUT IF ITS NOT THAT COLD OUT IT SHOULD START IF YOU HAVE ENOUGH BATTERY POWER MAYBE THERES NOT ENOUGH FUEL GETTING UP TO THE THROTTLE BODY HOPE THIS HELPS
Oct 23, 2008 | 1997 Volkswagen Jetta
Dryers Logo
132 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
