Question about Cell Phones
IPhone 7 is not ringing? - Cell Phones
How do I set the number of rings?
    These are instructions on how to set the number of rings before your iPhone goes to Voicemail. You can increase or decrease the amount of time your iPhone rings by following the simple steps below. Press the Phone icon in your iPhone's dock. Press to select Keypad from the tabs at the bottom of the screen.Jan 25, 2009
    How to Set the Number of Rings Before Your iPhone Goes ...
    www.iclarified.com/.../how-to-set-the-number-of-rings-before-your-iphone...
Jan 13, 2016 | Vtech DECT 6.0 Digital Cordless Phone
My calls go to voice mail
How to stop iPhone calls going straight to voicemail - iOS 7 tip
www.macworld.co.uk/.../how-stop-iphone-calls-going-straight-voicemail...
May 28, 2014 - Do your iPhone calls go directly to voicemail? ... I don't remember setting my iPhone to Do Not Disturb, and it appears nor do most people ...
iPhone 5 calls go straight to voice mail ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Dec 25, 2013 - Madman, your advice solved the problem on my wife's phone. It wouldgo to voice mail very often, seemingly for no reason. When I'd call again, ... iphone 6 going calls going directly to voice mail
Jul 20, 2015
My iPhone doesn't always ring, why?
Oct 28, 2013
calls going straight to voice mail
Feb 24, 2013
Calls going Straight To Voicemail
Jul 3, 2010
More results from discussions.apple.com
Troubleshooting Calls going straight to
Dec 30, 2015 | Cell Phones
I upgraded my iPhone 4 to ios 7 and it stopped ringing out. It only vibrates.
did you turn off the sound? it's a switch on the side of the iphone
Oct 03, 2013 | Apple iPhone Cell Phones
IPhone when in dock doesn't ring on messages or calls.
When your iPhone is plugged into the dock be sure that your volume is turned on loud and also that the dock is on. if your iPhone is plugged into the dock but the dock isn't on your iPhone is not going to ring out loud.
Jan 20, 2013 | Apple iPhone 5
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
