Question about Kubota Garden
I have hooked up the hydraulics and the electrics on my Kubota gr 2120 and the main carriage will not lower to pick up the cutting deck please
5 Suggested Answers
  • 24 Answers
SOURCE: cutting deck of mower not lowering
Did you check the wires goin to the motor under the frame to see if one of them came disconnected? Or...you might need a new switch.
Posted on Aug 22, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
SOURCE: Why does the engine of my Kubota ride on cut out when cutting
Sounds like you have a bad safety switch somewhere, possibly the seat switch.
Posted on Aug 10, 2012
Testimonial: "Thanks for this suggestion. I'll check it out."
  • 48 Answers
SOURCE: How to lower deck to get closer cut on zd326 kubota
Is there a knob behind the seat that controls rate of drop? If so try turning it.
Posted on May 11, 2017
Hydraulics are not working on my GF 1800 Kubota lawn mower
Check for fluid level and operation of master cylinder.
Sep 02, 2017 | Kubota Garden
May 11, 2017 | Kubota Garden
Where do I add hydraulic fluid on a kubota b1750 tractor
There should be a cap on the transmission cover behind the seat. It may have a rubber hook shaped breather hose on it.
Oct 16, 2016 | Kubota Garden
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
#1 my kubota gr 2120 diesel lawn tractor wont start in todays minus six degrees even I used the glowplugs. #2 i wanted to push the tractor out of the barn wont budge?
Throw a tarp over the tractor. put electric heater under tarp and warm the tractor up. #2 Most hydrostatics have a release lever that allows them to be moved.
Nov 20, 2014 | Diesel Garden
Free lawn mower manuals
http://www.kubota.com/part/parts.aspx
if you start here, you maybe able to find the manual
Jul 16, 2014 | Kubota Garden
T1770 cutting blade removal
Kubota blades, are they counter thread
Feb 14, 2013 | Kubota Garden
Aug 10, 2012 | Kubota Garden
Cutting deck of mower not lowering
Apr 28, 2009 | Garden
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
