SOURCE: RCA RCU403 3-Device trying to control GPX DVD player???
It may not be able to run the GPX dvd player as GPX is not a mainstream brand, if you have the original GPX remote, you might purchase a learning remote that can copy remote codes from the original, I have seen these Learning Remotes from around $20 by Phillips Magnavox if I remember correctly.
SOURCE: remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
SOURCE: trying to program my dvd player with my lg tv remote
Turn on dvd player by hand using your lg tv control push set up dvd plus code.pointing for 15 seconds.
SOURCE: Region hack needed for GPX PD907B DVD Player
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
SOURCE: I have an auvio 15-304
i have an Auvio 15-305, so this might help. Manual Code Search.
1) Power on the device that you want to control. For VCR and DVD players, you must insert a tape or disc first.
2) Press and hold SET, then press (TV, VCR/DVD, AUD, DVR,SAT/CBL, AUX) at the same time on the remote. The LED will stay lit indicating it is on setup mode. NOTE: DO NOT HOLD DOWN THE KEYS MORE THAN 3 SECONDS OR THE REMOTE ENTERS AUTO SEARCH MODE.
3) Press POWER on the remote. The remote enters a manual code search mode, the LED will start flashing.
4) Press POWER on the remote continuously until the device turns off.
5) When it turns off, turn on the device manually. then try pressing the other buttons on the remote except for the POWER, SET, and DEVICE keys.
If most of the buttons work then press the selected DEVICE key that you selected in Step 2.
i hope this helps.
