Question about Home Security
How to enter code on stalwart safe - Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    My safe, a Cathedral EA15 Will not lock. Any suggestions people?
    Instructions
    1. 1
      Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
    2. 2
      Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
    Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
    1. 1
      Enter your code to open the safe.
    2. 2
      Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
    3. 3
      Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
    1. 1
      Use your code to open the electronic digital safe's door.
    2. 2
      Locate and remove the battery cover on the inside of the door.
    3. 3
      Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
    4. 4
      Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
    Feb 08, 2015 | Locks & Locksmithing
    Set combination for paragon lock & safe
    TO SET UP OR CHANGE A USER CODE
    1. With the door open, locate the red button on the back of the door near the hinge.
    2. Press the red button and listen for the beep.
    3. Immediately enter your new pass code (3-6 digits long)
    4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
    NOTE:
    This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
    first pass code entered.
    SETTING UP OR CHANGING A MANAGER PASS CODE
    1. Open your safe with the pass code you wish to change and leave the door ajar.
    2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
    New user pass codes may be 3-6 digits long.
    3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
    http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
    Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
    How can i drill a hole into my keepsafe wall safe to open it?
    Keep the drill motor in the toolbox, you'll likely just ruin the safe.
    Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
    There are 3 possible ways to unlock and access
    the safe:
    1. Factory code
    (Found on the first page of the factory guide) You can
    always open the safe by entering the pre-set 5-digit
    factory code. This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can
    program the safe to open using a 5-digit user code
    of your choice.
    3. User pin
    If you wish to give someone else temporary access
    to the safe, you can program a 5-digit user pin that
    can later be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    To add:
    1. Press the Prog key , then enter the 5-digit
    factory code.
    2. Enter the 5-digit user code of your choice.
    To delete:
    1. Press the Prog key.
    2. Enter the 5-digit factory code twice.
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working,
    please check batteries before calling Sentry
    Customer Care.
    Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
    Hoover 550 dribble in on both hot water and cold water fillings....have checked filters and hoses, all is good. Any ideas?
    This is typical of ageing of the inlet water valves which would need to be replaced. Both valves giving the same problem at the same time is a little unusual as it is usually the cold inlet that fails. However if you are a stalwart who always uses a hot or warm wash rather than a cold only wash this might explain the dual valve problem. I am assuming that you have checked that there are no water pressure restrictors fitted in the water pipes which would give the same effect. Also be sure that the little round filters in the hose ends( check both ends of each hose) are not partially blocked. You can clean them with a hard toothbrush, or buy new ones from your local hardware store.
    Play Safe ! Never attempt washing machine repairs with the Power connected and play it safe by only attempting to fix things you truly understand the technicalities of.
    Oct 28, 2011 | Washing Machines
    I need to change the combination on my sentry S 3517
    Locksmiths recommend
    two ways to program a user code.A
    1. Press the Program key.
    2. Enter the Factory Code. The green LED remains ON while you enter the 5-digit user code of your choice.
    After 5 digits are entered the green LED turns OFF.
    (To enter a new User Code, repeat these steps.)
    B 1. Press the red button inside the safe. The lock will “beep” and the green LED will come on.
    2. Enter a 5-digit user code. (To enter a new User Code, repeat these steps.)
    Keep your new user code secure.
    Nov 13, 2009 | Sentry Fireproof Safe
    Change the combination to a Sentry 2260 safe. I have original combination and all I just need to change the combination.
    Safe and vault techs would advise you
    2. Press it a second time.
    3. Enter your 5-digit User Code. The green LED remains ON.
    4. Enter the 5-digit Password of your choice (any combination
    except 00000.) After 5 digits are entered, the green LED
    turns OFF.
    (To enter a new Password, repeat these steps. To erase the
    Password, press Program twice, enter your User Code and then
    enter 00000.)
    Jun 08, 2009 | Sentry Fireproof Safe
    Sentry Safe (DSW3607 Model) Won't Open
    I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
    Mar 22, 2009 | Sentry Fireproof Safe
    Home Security Logo
    148 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
