Question about Element Televison & Video
Usb wont work on element tv - Element Televison & Video
Soo I accidentally pressed the USB button on the element controller and I have no idea how to take it off again sooo...
The USB button is a dedicated shortcut key to select the USB source. To change to another input, press the Source button repeatedly until you have the desired source selected and then press OK. (On the Element ELEFW3916 TV, it's the lower side of the button above the power button on the side. On the remote, the source button is between the volume - and channel down buttons. That puts it below the mute.)
I hope this helps. Please post a comment with the model of your Element TV, if you don't see an Input or Source button on the TV or remote.
Jul 17, 2017 | Element Televison & Video
How do you use the usb drive on back of the 32inch element tv model ELFEFW328
If you wish to get some details; check the site linked here. Pull up older posts...
Aug 06, 2016 | Element Televison & Video
I cant get my files on the usb stick to work in the element 50 inch led tv
You may be using a file format that the TV doesn't recognize. .
Dec 31, 2014 | Element Televison & Video
Browse your brand name and model from internet. Download firmware from internet into a USB. Connect USB with TV. Go to last option stage and update firmware from USB.
Oct 09, 2014 | Element Televison & Video
Replaced 3 capcitors today and tv still wont power up, element flx3711b lcd tv
check D7 and small cap to the right(forgot # returned tv) in the power supply area.i found diode leaky and cap dry.Thats how i fixed the blinking red light.hope it works.
Mar 07, 2011 | Element Electronics FLX3711B 37 in. LCD TV
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Element LCD TV owners - Using the VGA port may crash your TV!
I bought two of these tv's and they worked fine,I hooked up a computer to both of them and blam smelt smoke in one and the other wont come on either. The computer takes them out. It is a common problem with this TV.
Nov 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Televison & Video Logo
24 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
